Headlights working running lights aren't???
Hi I have a pretty odd situation.. My headlights are working but my running lights aren't? My dashlights and night time running lights dont run at all. But, my headlights, brights, turn signals, and brake lights work fine. Does anyone have any suggestions as to what the sources of the issue might be?? I was reconnecting my foglight button when it all stopped working. I did check for all the fuses and they were fine.
Moderator
you may have a blown fuse somewhere. start by checking there. if you put in a new fuse and it blows dont bump it up with something higher because if you have a short somewhere it can cause a fire as the fuse will not blow out.
![]() ![]() BUILD 2 IN PROGRESS |
I did check the fuses and replaced them with the factory level. Still no hope I have looked across the entire internet for an answer..
Fast Enough For Now
We had a thread very identical to this a while back, but i cant seem to find it. The person had the same problem as you and people responded that there could be a number of issues, including the headlight switch could be broken which is a very common problem with our cars. I know you posted in the right section but you might get more replies if you post in your specefic car section (99-04, 94-95 etc).. hope that kinda helps ya.
![]() 00 Mustang GT Roush Stage 2 body kit,Side exhuast kit,Stock motor, Light bar, Cobra R rims, 5%tint rear, 20% front Myspace.com/510jatt "Music is my life, Driving is my Drug" TOPLESS MUSTANG CLUB |
Alright thanks guys. I am gonna take it to ATI since my friend goes there they maybe able to check it out. And refering to the headlight switch would that still apply if my HIDs do come on??
Fast Enough For Now
yes. Im not sure technically how it works but when i had this problem, my headlights were working just fine, but all the interior lights were gone. thankfully, my problem was only a fuse. good luck.
Fast Enough For Now
it was under the dash.. my cousin did it ill let u know wen i find out
Problem was solved. The guys at ATI figured out that it was indeed the headlight switch. It wasn't physically damaged I guess just internally fried it. I'll be replacing that for $8.
Thanks everyone for the suggestions and help! |
Threads Similar to: Headlights working running lights aren't???
| brake lights not working | homeboy2kfun | Audio/Video | 3 | October 17th, 2008 12:18 PM |
| Speaker Clicking Noise And Dash Lights Not Working | Lastofthe5.0's | 5.0 Mustangs | 5 | April 11th, 2008 01:01 PM |
| 1994-98 Mustang owners-Possible brake lights not working | raroboy | General Tech | 1 | April 15th, 2007 12:28 PM |
| brake lights aren't working! | 96DropTop | General Tech | 10 | April 8th, 2007 04:15 PM |
