2001 Cobra
13.5
Please Help about fuses
long story short...i i grounded out the cigerette lighter i was hoping someone would have a fuse diagram they could scan and post in this thread or just tell me which one it is PLEASE HELP speedometer dont work without it...thats part of the long story
![]() MM New Edge Cobra Crew #11 |
Resident DJ
'01 Cobra Vert.
Wraither where are you?
2001 Cobra
13.5
Resident DJ
'01 Cobra Vert.
A member on here...he's the electrical guru and will get you all your diagrams and stuff
![]() He's a great guy and if he helps you out be sure to give him some reps
2001 Cobra
13.5
i realized right after i posted that what you were talking about ok i hope he reads this tommorrow....do u have a fuse diagram you could look at
Resident DJ
'01 Cobra Vert.
No, I can get it tomorrow night...I'll have access to AllData tomorrow at the shop.
But look under your dash for the fuse box. Pull the lid off and look on the underside of the lid and see if there's a diagram on there. There should be.
2001 Cobra
13.5
i looked there i have no lid thats my problem...it was a used car
Resident DJ
'01 Cobra Vert.
Well that sucks. Hold on.
Resident DJ
'01 Cobra Vert.
2001 Cobra
13.5
that was really help full but i didnt see anything that was related to the cigerette lighter
Resident DJ
'01 Cobra Vert.
The cig lighter is prolly a 12V source. Dunno if that helps
but I tried.
2001 Mustang GT convt
why dont you just check all the fuses under the dash to see if any are blown? you can either pull them all which would take maybe 5 mins or you could use a test light to them that would take maybe 2 mins hope this helps
mods-Short ram air intake, P.P. 70mm throttle body, o/r H pipe, magnaflow catback, Nitto 555 tires, Steeda short throw, Steeda UDP, sct x3 tuner. Next-lowering springs, Mac LT's, 3.73 or 3.90 gears, black saleens or cobras, and maybe some juice
Resident DJ
'01 Cobra Vert.
^Yeah I was going to say that but I was sorta assuming that'd be something to try to begin with...
2004 V6 Coupe
I got a small fuse kit from pep boys and it had a tester in it, and I was able to find two blow fuses with it, that's probably an easy way to do it. Another way is if you have a multi meter. Just use that to check if you have current going through the fuses by touching the two metal spots on the top of the fuse. Also you can google a fuse diagram and find one, or if you have an owners manual there is a whole section in it about your fuses and where they are.
Moderator
did you speedo needle stop moving or the illumination is gone?
![]() ![]() BUILD 2 IN PROGRESS |
Resident DJ
'01 Cobra Vert.
About damn time you get in here Wraither
#17 | |
2004 V6 Coupe
Check the 4th chart on the bottom of post 3, it says that it is fuse 1, the first one in the chart... maybe thats it |
Moderator
yeah thats the one for the cig lighter. it is a 20amp yellow fuse.
Moderator
, I know, I know. been busy with stuff. Might be moving up to DC among other things
2001 Cobra
13.5
it just stopped moving...i shorted out a black box from brothers performance warehouse to recalibrate my spedometer to my gearing
... so my needle isnt working and it isnt racking up miles on my car
Threads Similar to: Please Help about fuses
| help with my fuses.... | Traidmarx | 5.0 Mustangs | 2 | November 21st, 2008 08:08 PM |
| Fuses.. | RhadCundell | V6 Mustangs | 6 | January 12th, 2008 01:50 PM |
| Fuses | AJRight 2008 | V6 Mustangs | 1 | August 21st, 2007 01:44 AM |
| fuses...... | rioswimmer | 5.0 Mustangs | 4 | August 13th, 2007 06:27 AM |
| fuses? | thetrooper31 | V6 Mustangs | 7 | July 16th, 2007 07:36 PM |
