I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
LED accent lights
The wife and i are looking at putting a few little LED accent lights in her Xterra and i wanna know what i'm gonna need to install these. i want em to come on when i turn on the lights, obviously, cuz her cab/cockpit is just so rediculously dark. the locations may change as we decide excatly where to put em. help? + reps for all who help
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
SVTfocus, F250
the easiest way to wire them in is to find the illumination wire behind the stereo and wire them into that its just a 12v+ and find a ground. they will come on with the parking/headlights
Moderator
^yup, if you give me the year I can pull up for you where to find you door trigger wires or parking light wires, the color, and location where you can find it.
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; April 17th, 2009 at 01:53 AM. |
2008 GTI
14.65 @ 99.83
2006 Xterra X 4.0L 2WD AT
2008 GTI
14.65 @ 99.83
thanks in advance and repz!
2003 Mach 1
Moderator
Parking Lights GRAY (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
this is for you parking lights so that whenever you turn on your parking lights they come on. *****Make sure you test this wire before you tap into it***** if you want them to come on when you open the doors then I will have to walk you through on how to do it as your door trigger wires are a negative trigger and you need a positive trigger in order for it to work. Not hard at all just let me know.
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; April 17th, 2009 at 12:49 PM. |
Moderator
Parking Lights BROWN (+) DRIVER'S KICK PANEL (if you want them to come on with your parking lights)
All Door Trigger BLACK/BLUE (+) GRY DRIVERS KICK LOW UNDER RUG (if you want them to come on when the door opens) *****Make sure to test wire before tapping into it*****
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; April 17th, 2009 at 12:48 PM. |
Moderator
all are listed as
Wire color/ +/- trigger (polarity)/ location where to find.
![]() ![]() BUILD 2 IN PROGRESS |
2008 GTI
14.65 @ 99.83
thanks man! you da shiznit!
Moderator
Moderator
also, when you test these wire (if you have a multi-meter) they will read 0 when you probe the wire and then when you open a door or turn on your parking lights it will go up to about 12v. turn the lights on and off or close the door and open it just to make sure that it is the wire. when doing this it will continue to go from 0 (switch off or door closed) to 12v (switch on or door open)
2008 GTI
14.65 @ 99.83
man, you are some kind of sorcerer. you dunno how much this helps me!
Moderator
2000 Convertible V6
Also thinking about this kind of thing. (as well as the fact that everything I decide to do is a pain in the ass..) but what if you wanted them to come on when the doors are open, as well as when the lights are on?
Moderator
All Door Trigger BLACK/WHITE (+) 20 PIN CONN. PIN 3 AT THE GEM MODULE UNDER THE LEFT SIDE OF DASH IN DRIVERS KICK PANEL
this is what you are looking for. all you would have to do is when you purchase your lights is to take the positive and tap it into the above wire then take ground to a bare piece of metal. you can read what I wrote above on how to test the wires if you have a multi-meter.
\/ Hidden Bewbs \/
01 Cobra Vert
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
Where are ya'll putting lights in the stang? I've been wanting to do this, but can't decide where to put them
![]() MM Cobra Club #66 |
Threads Similar to: LED accent lights
| LED Pony Lights | DanishStallion | Multimedia | 25 | January 13th, 2009 09:38 AM |
| LED dome lights | gooberhead320 | Audio/Video | 6 | July 25th, 2007 02:45 AM |
| LED courtesy lights | Kuro | 2005 - 2010 | 1 | June 27th, 2007 04:52 AM |
| LED lights on wheels - Legal? | theeipi | Visual | 11 | April 25th, 2007 08:57 PM |
| Y2K LED Tail Lights | adam007g | V6 Mustangs | 3 | September 18th, 2006 02:37 AM |
