#21 |
2001 mustang bullitt
yo and that big black plug has 2 prongs missing out of it...is that fuked up?
#22 |
Moderator
do you want to watch DVD's while you drive?
![]() ![]() BUILD 2 IN PROGRESS |
#23 |
no its fine to wire it to the e brake..i might fool with that later
#24 |
Moderator
no, its fine
#25 |
Moderator
alright cause you are gonna need a relay for it that I can show you how to hook up later. just PM me.
do not try to wire these up while you have the best buy harness plugged into the car. 1) all the wires on both harness's you are gonna match color for color, IE... yellow to yellow, red to red, black to black. there will be a couple of wire that are gonna be left over on both harness's. ford harness Main harness- Black/White (not needed) Orange (illumination) not needed as it already has internal illumination Orange/black (dimmer) up to you if you want to hook this up Pioneer harness- Violet/White- Reverse speed signal (needed only if you have navi which you dont) on the secondary ford harness with the rca's you will need to hook up the 2 Blue/White wire (amp turn on) to your Blue/white wire from your pioneer harness. also there will be 2 Black/white wires that you need to hook up the the Black wire from the ford harness (those wires are your amp ground). then you will hook the rca's to your sub output as mentioned.
![]() ![]() BUILD 2 IN PROGRESS Last edited by wraitherx; April 22nd, 2009 at 10:46 PM. |
#26 |
so when im doing this the black part will go into the HU and then do i have to cut into the wire thats already there and splice these ones on the harness?
#27 |
Moderator
the deck all you have to do is to slide the cage out and fit it into the dash kit that you baught and lock it down with the taps that it has. if it didnt come with the cage then you will take the screws that were supplied with the deck and "ISO Mount" it to the dash kit.
If you are ISO mounting it then you will have to use the pieces that the dash kit came with that have screw holes on it that will attach to the sides of your dash kit. place the H/U into the dash kit to your liking, match up the holes from the dash kit to the holes on the side of your H/U, screw it down and your good to go.
#28 |
Moderator
it will be easier for you if you were just to take the Blue/White wires (should be 3) and the Black/White and Black wires (4) and just tie them into each other so that you dont have to splice. Get what im saying?
#29 |
fuk man idk hold on on the harness with the rca i have 2 blue/white and 2 blue and black ONLY
#30 |
Moderator
Blue/white to Blue/White (total of 4 wires connected together)
Black with black/white (total of 4 wires connected together)
#31 |
fuk so the big black plug with the wires on it will be connected to the white one with the rcas on it right?
#32 |
Moderator
yeah pretty much, then they are all gonna connect to the same wires on the pioneer harness.
#33 |
Moderator
so you will connect the blu/whites from both ford harness's to the Blue/White on the pioneer harness.
Then you will connect the Black and the 2 Black/white wires to the Black wire on the pioneer harness.
#34 |
dude this shit aint right i think hold on im gonna post another pic...the one with the rcas has 2 blue wires and 2 black...the large black harness with orange yellow green purple white grey pink ...and the other smaller black one only has 1 blue and thats the 'system remote control' wire?
#35 |
are you talking about i will connect it to the harness thats already in there? or to one of the 3 harness' i have in front of me?
#36 |
Moderator
you are gonna connect the 2 that you baught from best buy to the one that pioneer harness
#37 |
im sorry im slow with this shit yo
#38 |
yo idk which ones u talkin bout cause i didnt buy any from best buy..the pioneer harness is the small black one right with all the little tags on the wires right?
#39 |
Moderator
the one's on the left are gonna connect to the one in the middle of the picture that you sent me
#40 |
Moderator
wherever you got them from. It aint a problem man.
Threads Similar to: Opinions on a new deck.
| headliner deck | WLJohnson05 | Audio/Video | 22 | June 21st, 2008 07:23 AM |
| My deck is swallowing my CDs!! | Murderjetz | Audio/Video | 6 | August 8th, 2007 02:39 PM |
| How do I pull out my deck?? | Murderjetz | Audio/Video | 14 | July 11th, 2007 10:25 PM |
| CD Deck | lwhitetrash88l | Audio/Video | 5 | April 17th, 2007 10:19 AM |
| deck Height ? | New88MustangOwner | 5.0 Mustangs | 4 | March 5th, 2007 11:38 PM |
