Sound System Installation Problems!!! - Page 2
Old April 26th, 2009, 11:23 PM   #21
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
also, when do you need it by?
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:23 PM   #22
2004 V6 Coupe
04stang123456789 is on a distinguished road
Old April 26th, 2009, 11:24 PM   #23
2004 V6 Coupe
it doesn't matter when I get it, the sooner the better, but it doesn't really matter
Old April 26th, 2009, 11:28 PM   #24
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
alright how does $10 plus shipping sound? shipping shouldnt be no more then $5
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:28 PM   #25
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
it would have to be sometime next week as right now im out of town on a conference for my company and wont be back until Monday of next week
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:30 PM   #26
2004 V6 Coupe
that sounds great, do you want me to pay you with paypal, or something else?
Old April 26th, 2009, 11:31 PM   #27
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
also, a couple things im going to need.
1) outside diameter of tweeter
2) are you going to be using any of the mounts that it comes with?
3) if using mount I need the dimensions of the mount plus the height with the tweeter inside
4) if not using any brackets I need the height of the tweeter alone (from bottom to highest point)
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:33 PM   #28
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
paypal. I will PM you when i get back. Ill make it, take pictures of it so that you are happy with it, then ill give you my PAYPAL addy to send the money to. How does that sound? Just want to make sure that you are seeing what you are getting and that you are happy with it.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:37 PM   #29
2004 V6 Coupe
that sounds great, thanks a lot for everything. All I have is the tweeter, so I am not using any bracket or mount. I will be able to get you the sizes tomorrow when I can measure them. I will PM you the measurements, so all you need it the measurments of the diameter of the tweeter and how deep it is right?
Old April 26th, 2009, 11:43 PM   #30
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yup, thats it. and no problem at all bro glad to help out a fellow enthusiast
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:44 PM   #31
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
when i do it I will also send you instructions on how to run your wires and where to mount your x'over box with pictures of mine on how i did it to make it simple for you.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:46 PM   #32
2004 V6 Coupe
Thanks a lot, that would have been my next question to you, because I did not know where I should mount it.
Old April 26th, 2009, 11:46 PM   #33
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah, there really isnt alot of places but I found a great spot that you will see in the pictures.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:47 PM   #34
2004 V6 Coupe
Somebody told me that the crossovers were very fragile and I should wrap them in foam or something, is that true?
Old April 26th, 2009, 11:49 PM   #35
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
no, there is no need to wrap them in foam as long as they are protected from the elements. there is a chip board that is encased in plastic that protects it.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:51 PM   #36
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
ive had my xovers mounted on my door for about 3 years now and never had a problem with them and ive mounted them in the same place on many mustangs with no one ever coming back cause of problems fo were it was mounted.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:53 PM   #37
2004 V6 Coupe
Ok, cool sounds like you found a good spot for them. Do you have them in the door behind where the speaker goes, because I noticed a large area behind it?
Old April 26th, 2009, 11:55 PM   #38
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
nope, ive got them screwed onto the door body right behind the door panel. if you were to lift up your switch bezel you will be able to see it just sitting there chillen
BUILD 2 IN PROGRESS
Old April 26th, 2009, 11:58 PM   #39
2004 V6 Coupe
haha cool, do you think you could also make me some adapters for my midbass speakers for extra money because I was just looking at the adapter and I do not think I will be able to shave enough off for it to fit. It appears that there is a 5 1/2" base of the speakers, and that is a lot of shaving to do
Old April 27th, 2009, 12:01 AM   #40
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
the size of your speaker is 6.5 or 6 1/2 right? what is diameter of the basket (the portion under the speaker)? Im just not seeing why its not fitting.
BUILD 2 IN PROGRESS
Threads Similar to: Sound System Installation Problems!!!
Screamin Demon Ignition System Installation 68 dlxcoupe 96-98 16 December 7th, 2011 09:50 AM
Step By Step Sound System Installation 00-04 Mustang GT mixedbreed02gt Audio/Video 5 July 26th, 2010 10:00 AM
Sound System trueballerisme 2005 - 2010 23 January 18th, 2008 08:50 AM
Idle problems after Plenum/TB/o/r X pipe installation throwedoff 99-04 80 May 9th, 2007 03:02 PM
Sound System WeCircleTheProblem Audio/Video 10 February 22nd, 2007 09:37 PM
