Sound System Installation Problems!!!
Old April 25th, 2009, 01:11 PM   #1
2004 V6 Coupe
04stang123456789 is on a distinguished road
Exclamation
HELP...I am trying to put my new speakers in my 04 stang and I cannot figure out how to get the tweeter housing off to put the new one in! Can somebody please help me ASAP I need to get it in soon!
Old April 25th, 2009, 05:10 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
that tweeter grill just pops off... then the back housing has i believe a 8mm bolt holding it to the door and thats it.
BUILD 2 IN PROGRESS
Old April 25th, 2009, 06:59 PM   #3
2004 V6 Coupe
i have phoenix gold rsd 6.5" components with tweeters, do you think the tweeters will fit in the stock housing?
Old April 25th, 2009, 07:07 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
they might be smaller but you can get a metal bracket and custom make your own its fairly easy.
BUILD 2 IN PROGRESS
Old April 25th, 2009, 07:40 PM   #5
2004 V6 Coupe
yea, thats what I had to do with the door speakers for the mid bass. Thanks again for all of your help
Old April 25th, 2009, 07:42 PM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
glad to be of help
BUILD 2 IN PROGRESS
Old April 26th, 2009, 03:51 PM   #7
2004 V6 Coupe
I have another question for you... Is there somewhere that I can purchase speaker adapterts for my new speakers? If there is, could you tell me a site or send a link? I need them for the mid bass as well as the tweeters. I cannot make my own because I do not have the material or tools to do so.
Old April 26th, 2009, 04:32 PM   #8
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
here are the 6 1/2 to 6x8 speaker adapter that i was talking about. alot of the component systems come with this in the packaging. as fas as the tweeters are concerned Im not sure if they make one.
Amazon.com: Scosche SA68 Convertible 6x8-Inch Speaker Adapter - Pair: Electronics Amazon.com: Scosche SA68 Convertible 6x8-Inch Speaker Adapter - Pair: Electronics
check this site out as it will give you some insight on how to make the brackets for the speakers as well as the tweeters. just got to get a hold of some ABS plastic. You can go to any audio shop and ask them for a 12x12 piece of ABS plastic as they keep on hand regularly
Fush's Terminator Site: Mobile Audio Upgrade
BUILD 2 IN PROGRESS
Old April 26th, 2009, 07:42 PM   #9
2004 V6 Coupe
The problem is... I bought those same speaker adapters, except from a different site. I got them from a site called sonicelectronix.com... here is the link
Scosche SA68 Adapter Brackets Speaker Installation Car Accessories and Installation Car Audio and Video - Sonic Electronix
the problem is that I got them and they did not fit my speakers! I have the 6.5" components and they didnt fit. Here is a link of the speakers that I purchased...
Phoenix Gold RSd 6.5 (RSd6.5) (rsd65) 6-1/2" Speakers Car Speakers Car Audio and Video - Sonic Electronix
it's odd that they do not fit, also you are not in the business of making tweeter adapters right?
Old April 26th, 2009, 08:16 PM   #10
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
im thinking that the basket of your speaker is larger then 5". if this is so then you are gonna have to modify the opening on the bracket to make the speaker fit. i can make you one if you would like, or I can show you how to make it.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 09:24 PM   #11
2004 V6 Coupe
What would I have to use to modify the bracket? and how much would you charge to make me some brackets? and I do not think I could make my own because I do not have a lot of tools to wor with
Old April 26th, 2009, 09:34 PM   #12
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
to modify the bracket for the subs all you need to do is to make the opening a little bigger you can start by etching a circle around the cutout (a little bit bigger) and you can use a blade or anything to cut through the ABS plastic. now as far as the tweeters are concerned what you can do is get a piece of ABS plastic, take your stock tweeter and trace the outline onto the abs, then cut it out. this is basically just like the sub brackets. next thing is you are going to take the tweeter and trace its outer dimension onto it, cut it out and then take your tweeter and mount into the hole using some hot glue. I know you are thinking "hot glue?" but trust me it works and holds. make sure you use the industrial strength glue as it adheres alot better. I used metal brackets on mine.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 09:41 PM   #13
2004 V6 Coupe
where could I get ABS plastic, and what could I use to cut through it in a perfect circle?
Old April 26th, 2009, 09:42 PM   #14
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
if youve got a drill you can use a "hole saw" it cuts out a perfect circle. hold on im gonna make you a diagram on what ive made for my customers.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 09:56 PM   #15
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
almost done
BUILD 2 IN PROGRESS
Old April 26th, 2009, 10:11 PM   #16
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
here you go bro
sorry it took so long, this is what i made for customers with 460's and wanted to install components. This is made out of ABS.
BUILD 2 IN PROGRESS
Old April 26th, 2009, 10:16 PM   #17
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
if you want me to make you one let me know and I can
BUILD 2 IN PROGRESS
Old April 26th, 2009, 10:18 PM   #18
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
also, obviously it wont be that deep so that the tweeter is all in there, i would make it so that is shallow enough that you tweeter is just about touching the 460 grill
BUILD 2 IN PROGRESS
Old April 26th, 2009, 10:21 PM   #19
2004 V6 Coupe
if you could make me a bracket for the tweeter that would be great, I don't think I would be able to make it myself and I think you would do a much better job at it. How much will it cost for you to make it and ship it to me?
Old April 26th, 2009, 10:23 PM   #20
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
whats your zip?
BUILD 2 IN PROGRESS
Threads Similar to: Sound System Installation Problems!!!
Screamin Demon Ignition System Installation 68 dlxcoupe 96-98 16 December 7th, 2011 08:50 AM
Step By Step Sound System Installation 00-04 Mustang GT mixedbreed02gt Audio/Video 5 July 26th, 2010 09:00 AM
Sound System trueballerisme 2005 - 2010 23 January 18th, 2008 07:50 AM
Idle problems after Plenum/TB/o/r X pipe installation throwedoff 99-04 80 May 9th, 2007 02:02 PM
Sound System WeCircleTheProblem Audio/Video 10 February 22nd, 2007 08:37 PM
