jensen head unit
Old January 24th, 2007, 03:02 PM   #1
mi01ke is on a distinguished road
jensen head unit
i have a jensen vm9510ts can i just ground this wire or for this model do i need to get a toggle switch. i hear you can ground it but im not to sure anyinfo would be great thanks
Old January 24th, 2007, 10:35 PM   #2
jerb43 is on a distinguished road
i had a jensen 7" motorized monitor in mine, if the wires are like the one i had, all you need to do is GROUND the PINK wire, and that is it! promise, i grounded mine to the black wire on the harness, and it worked fine!
hope this helps!
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust!
Old January 25th, 2007, 01:31 AM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if its a newer jensen there is a process that you have to go through in order to get it to play in which the toggle switch wont work. If it is a new one you would have to engage and disengage the parking brake 3 times in order for it to work.
BUILD 2 IN PROGRESS
Threads Similar to: jensen head unit
Help w/ stock head unit eprench Audio/Video 1 September 16th, 2007 10:35 AM
Head unit ebo 4356 96-98 8 September 12th, 2007 11:34 AM
head-unit johnbarberr Audio/Video 11 May 29th, 2007 07:47 AM
new head unit help Pharoh Audio/Video 6 February 3rd, 2007 12:09 AM
Need Help With Head Unit Install Teggy_Boy Audio/Video 1 January 18th, 2007 06:54 PM
