PIONEER SPEAKERS
Old January 31st, 2007, 01:18 AM   #1
PONYBOY14 is on a distinguished road
PIONEER SPEAKERS
SO ON MY 98 GT DO I NEED 6X8 OR 6X9? GONNA GET SOME PIONEERS I THINK. WILL THEY HAVE THE CONNECTORS AT WALMART? I CAN ALWAYS GO TO BEST BUY OR CIRCUIT CITY TO GET THEM. ANY IDEA HOW MUCH THEY ARE?
Old January 31st, 2007, 11:11 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
6x8 alll the way around unless you got a vert. The harnesses at best buy are $8 you will just need two packages cause there are 2 to a pack.
BUILD 2 IN PROGRESS
Old January 31st, 2007, 11:27 PM   #3
ok
yea i got the mach 460 system. and the door speakers have been blown, so ima put the pioneers in it i think. unless... there's something a little cheaper that sounds better and can handle it.
Old February 1st, 2007, 12:35 AM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
are you going to be doing the installation yourself? are you replacing all 4 speakers? if you are doing the install it really isnt all that hard to do. when you take your door speakers out you will see a gray plug now if you look directly up towards your tweater you will see that same plug connected to the tweeter. That is the plug that you want to use but you will not be able to use your tweeters anymore. The reason being is that the doors on the mach are mids, and the tweeters put out full range sound. if you were to hook up your speakers to the 6x8 plug it will sound muffled. As far as the rear deck is concerned you cant place the new 6x8's in the amp rack for the mach so you will have to drop it. There are 6 bolts on top to the left and right and then the whole rack will drop just unplug it and your good to go just put the new speakers in and then thats it. I recommend either 3 or 4 ways up front and then 2 ways in the back. Good luck
BUILD 2 IN PROGRESS
Old February 1st, 2007, 12:38 AM   #5
YA. IT AIN'T HARD I ALREADY GOT THA SPEAKERS OUT, JUST GOTTA GET THE NEW ONES AND CONNECT THA WIRES AND PUT EM IN.
Old February 4th, 2007, 06:49 PM   #6
AndyG47's Avatar
2002 Mustang V6
Slow
AndyG47 will become famous soon enoughAndyG47 will become famous soon enough
Running Pioneer TS-6870R's all around. 3 way 6x8's @ 220 watts max.
I cut the factory plugs off and used butt splices / barrel connectors (whatever you call them) to hook up the Pioneers.
2003 F150 - 5.4L V8 4x4 - 109K hard miles & still going FORD Tough----2002 Mustang 3.8L V6 - Currently undergoing "I'm not 17 anymore" demoding
Originally Posted by OneShotOneKill View Post
this thread has more fail in the first 5 posts than all of the "what exhaust?" threads in the v6 section.
Threads Similar to: PIONEER SPEAKERS
Pioneer AVIC-Z2 Youngin Audio/Video 2 May 15th, 2007 02:30 PM
Pioneer AVIC-N3 Ando32205 Audio/Video 7 April 23rd, 2007 01:29 PM
Pioneer radio install in 98 gt with mach 460 98gtmike Audio/Video 5 March 3rd, 2007 09:49 PM
