new head unit help
Old February 2nd, 2007, 01:18 AM   #1
Pharoh is on a distinguished road
new head unit help
installing new head unit have power no sound no mach 1 system 2000 mustang which wires are for the speakers?
Old February 2nd, 2007, 02:28 AM   #2
also wanted to know if i had to take out both units just to get full control through one i figured the tape deck had everything plugged up through it so i didnt need to take out the cd player.
2000 Mustang V6 5spd. (deceased)
1988 Monte Carlo SS (cruiser)
1993 Mustang GT 5spd (bruiser)
Old February 2nd, 2007, 03:33 AM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
get a harness, it will make your life so much easier. you can then buy a pocket to fill in the gap of your tape player or cd player wherever you decide to put it. when you get the harness just match color for color and your good to go.
BUILD 2 IN PROGRESS
Old February 2nd, 2007, 10:31 AM   #4
bought one after i got sick of trying to get the wires right but not everything goes into the harness the connectors are diff.
Old February 2nd, 2007, 12:08 PM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you should have a rectangular one that is gray, which is your power side, and then you should have a long elongated black square plug right?
BUILD 2 IN PROGRESS
Old February 2nd, 2007, 12:09 PM   #6
has anyone installed a stereo in a 2000 mustang and can tell me which set of wires are the speakers thats all i need to know is were the speaker wires are really appriciate it.
edit* i have the double din and there was a long grey plug then there was a square shaped black one on the same side of the tape deck then on the cd player they was a small rectangle connector and a smaller of the same square like connector there was also a square connector from the cd player i think to the tape deck.
Old February 3rd, 2007, 12:09 AM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
i dont think that on the 2000 that there was a double din radio. You should have a tape player up top and then a cd player at the bottom. Once you take out the decks and look inside you should see an amp at the bottom on the floor board, on the right of the amp there is a plug unplug it and go to best buy or circuit and as for a ford 5514 premium sound harness it will come with a gray rectanbular harness (which you will use for your power side), a elongated black square plug (speaker side but you will not be using it) and then another speaker adapter that has two female ends on it (this harness you will be matching up to the harness that you pulled off of the amp inside the center console and on the floor board, underneath the radios that you pulled out) you should be using the larger plug end and just cut it about half way between both ends. Wire it up to the harness from your radio and your good to go.
BUILD 2 IN PROGRESS
Threads Similar to: new head unit help
Help w/ stock head unit eprench Audio/Video 1 September 16th, 2007 10:35 AM
Head unit ebo 4356 96-98 8 September 12th, 2007 11:34 AM
head-unit johnbarberr Audio/Video 11 May 29th, 2007 07:47 AM
jensen head unit mi01ke Audio/Video 2 January 25th, 2007 01:31 AM
Need Help With Head Unit Install Teggy_Boy Audio/Video 1 January 18th, 2007 06:54 PM
