2001 Mustang GT
Having problem with JL Sub Need Help, Please
Well, It's hooked up to Alpine DVD/Nav deck. Amp is a Total mobile 300w and the sub is a 12"? JL sub. I bought the car about a month ago and it was working fine until sometimes it started to cut out. I either had to shut the alpine deck off then turn it back on or shut the car off and turn the car back on but now it doesn't work at all. I swear when i first turn the car on in the morning, I swear i can hear it bump once maybe but not for sure. Does anybody know what it could be, how i could fix it or how to go about narrowing what it could be such as the sub, amp, wiring, or deck
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Is your amp powering up? Check your ground wire.
88 mustang GT
check all the connections, esp on the amp, also the internals of the amp could be going out, ive never heard of total mobile before might not be known for reliability but who knows
2001 Mustang GT
Ill check the ground wire if I can find it and get back to you later
I've already checked the connections on the amp and they all look good. I've never heard of total mobile before i bought this car either and it does kinda seem cheap.
2001 Mustang GT
well, I figured out the problem. The guy that put the amp & sub in used to small of power wire I think 10 gauge and it burnt up the 30w fuse that's by the battery. Thanks for the help guys
88 mustang GT
damn 10 gauge is wayy small. make sure you get some nice 4 gauge in there. or at very least 8g
damn... I couldnt imagine a amp power wire that is 10g. I use 0G welding cable for my power wire.
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
2003 v6
wow 10g on a JL sub.... what was he thinking hahaha.... Nice you figured out the problem though
Moderator
yeah upgrade your wiring, not just power but the ground as well. if you want to what you can do is to use that 10 gauge power wire and use it as speaker wire to your subs and amp
as this is what I did
![]() ![]() BUILD 2 IN PROGRESS |
Threads Similar to: Having problem with JL Sub Need Help, Please
| AC problem = Tune problem? | SKRAPR | 2005 - 2010 | 11 | May 16th, 2009 01:29 AM |
| Transmission problem??? need help diagnosing the problem... | Tmac3320 | 99-04 | 19 | April 13th, 2009 01:58 AM |
| O Jesus! Problem After Problem! | mustangmanic | 99-04 | 94 | March 28th, 2008 04:36 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| Big Problem Or Little Problem? | wraitherx | 5.0 Mustangs | 17 | November 21st, 2006 09:45 PM |
