#21 |
Moderator
best thing would be to trace everything back to the computer. Thats what I had to do with my #6 COP as there was a break in the wire.
![]() ![]() BUILD 2 IN PROGRESS |
#22 |
Moderator
honestly just check every possible thing that you can. check everything in the vicinity of the area, grounds, connections, etc. then just check all the way back.
#23 |
Wax on, Wax off
Hmm... it seems that the wires leave the trunk and go under the car right above the gas tank. Gonna be a PITA to trace that wire back to the ECU if I have to.
Gonna try and get out there to check the wire tomorrow. Been so freaking busy.
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
#24 |
Moderator
those wires should be for the fuel pump. I dont recall the wires tracing underneath the car. I will check mine tomorrow and try to get you some pictures of tracing the wire back.
#25 |
Moderator
hmmmm now that I think about it. did you double check to make sure nothing was in the way of anything when you put your interior back together when you did your dynamat? it was you and not someone else, right?
#26 |
Wax on, Wax off
I remeber there was a large set of wires coming up from the passenger side through a odd rubber grommet, they split off and one went to each taillight's connector. I will double check it tomorrow as well.
#27 |
Wax on, Wax off
That was someone else. I had my interior taken all apart back in March when I repainted everything... but that was in March
#28 |
Moderator
<--------- fail horribly
ill try to get something up for you tomorrow as im certain that it doesnt run under the car
#29 |
Wax on, Wax off
Thanks man, your the best. Don't know what all us electronic idiots would do without you.
I can tell you how to fix a computer all day long... but I get lost with the car's electronics somehow.
#30 |
Moderator
no problem bro, thats what im here for to share the knowledge. nothing worse then an enthusiast who is greedy with his/her knowledge.
#31 |
Wax on, Wax off
So... out of the blue today the bulb is working. I'm not touching it until is messes up again.
#32 |
Moderator
, that just tells me that there is either a break, something clipped it causing it to ground out, or loose connection at the bulb. was there anything that you did that you think may have caused it to start working?
#33 |
Wax on, Wax off
Not that I can think of... I simply got in the car this morning and went to class and noticed the indicator on the cluster was not blinking fast.
I reinstalled my subs the other day, but I simply have them resting on my rear seat delete... never got near the trunk. The amp has always been hooked up, just had the box out. hmm... nope can't think of anything.
#34 |
Wax on, Wax off
And its not working again...
Didn't do anything to make it start/stop... looks like im gonna have to trace this wire.
Threads Similar to: One tail light bulb not flashing
| what does a flashing o/d off light mean? | Imran | 99-04 | 19 | November 4th, 2009 11:40 PM |
| O/D light flashing | Mustang Mike | 99-04 | 9 | September 12th, 2009 05:12 PM |
| Replacing tail light bulb on an '06 GT with the 1000watt soundsystem. | t3hlulzkiller | 2005 - 2010 | 8 | June 22nd, 2009 10:09 PM |
| OD off light flashing | PHXGT06 | 2005 - 2010 | 16 | June 19th, 2009 07:06 PM |
| Flashing O/D Light? | 06z28eaTer | 96-98 | 2 | December 26th, 2008 01:20 PM |
