Car alarm
I have a automatic v6 i want to get a alarm with remote start, do i have to get a copy of my electronic key to be put somewhere in the care before i can get the remote start?
#2 | |
Re: Car alarm
if you have a manual transmission the install will be a little more involved but not impossible
Moderator
got to best but of circuit city and the will sell you a 555FW it is a transponder with the little module instead of loosing a key it has the capsule that we attach close to ignition chamber where the keysense ring is located and we program the module off of BOTH of your keys. I dont know who charges $150.00 but we at best buy only charge $51.99 for the module and then $24.99 to install it. They also have one where we put the key inside the module (556U) but I dont like using those cause you will loose one of your keys. Check this out, this is what I use to pull up diagrams for all the car that I work on.
http://www.directechs.com/directwire...ss.asp?id=1728 oh yeah, not trying to be a dick, but you wont be able to get access to this unless you have a password, which is only given to distributors of DEI.
![]() ![]() BUILD 2 IN PROGRESS |
as others have said you dont have to use a key to make it work. this is what i bought and use for my viper 791xv with remote start, my car is also a manual.
It comes with instructions and its pretty easy to program and install
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
Moderator
thats exactly what I was talking about
Threads Similar to: Car alarm
| alarm | efulton95 | 94-95 | 2 | October 31st, 2007 10:53 PM |
| Do i have an alarm? | MustanG_guy17 | V6 Mustangs | 7 | August 18th, 2007 01:19 PM |
| Alarm won't go off | Murderjetz | Audio/Video | 11 | August 1st, 2007 07:57 AM |
| alarm?? | jat | 2005 - 2010 | 8 | February 9th, 2007 08:50 AM |
| Alarm | 232stang | All Other Vehicles | 2 | November 15th, 2006 01:31 PM |
