Audio issues
Old November 7th, 2009, 07:24 PM   #1
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
Audio issues
1. I need to know how to replace my upper corner driver door speaker , its a Mach speaker. I think its blown
2. I get a beeping sound and my head unit says audio failure, i notice the beep is comming from one of my back speaker which is also a Mach. Whats the deal with this, it goes away after a few seconds but is still anoying
Old November 7th, 2009, 08:23 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
the grill on it pops off just be careful with it and then unscrew and unplug the speaker.
If it is saying audio failure you may have a blown speaker or a bad amp that is backfeeding into the radio causing that beeping sound. If you want to test to see if you have a bad speaker you can hold down the # 3 and # 6 button at the same time and it will put the mach system into an audio test mode. You will hear a series of pops from each individual speaker so that you will be able to tell if one is blown or not. It will test the highs/mids first (those are the ones in the sail panel above each door and then there are 2 more in the rear deck) then it will pop all the subs at one time.
BUILD 2 IN PROGRESS
Old November 8th, 2009, 08:58 AM   #3
Matt.'s Avatar
12's?
i dont have the orginal head unit, i have an aftermarket sony one
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old November 8th, 2009, 09:10 AM   #4
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
if you have a reputable stereo shop around you, most of the time they wont charge you to just take your car in to check it and see what might be wrong with it. then if anything is blown, while your there pick up some new speaks!!
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
Old November 8th, 2009, 10:59 AM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
alright, if you have an aftermarket and it displays audio failure then you definetly have a blown speaker somewhere.
BUILD 2 IN PROGRESS
Threads Similar to: Audio issues
Audio Q Rattltrunk Audio/Video 3 March 20th, 2009 12:56 AM
Need help with audio!!! boylesjake200 Audio/Video 13 June 4th, 2008 11:09 AM
v6 audio Toph6888 Audio/Video 5 February 19th, 2008 10:31 AM
audio d2daj86 Audio/Video 3 October 29th, 2007 11:35 AM
Audio help wraitherx Audio/Video 6 January 30th, 2007 11:11 PM
