speakers
Old November 11th, 2009, 03:10 PM   #1
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
Ryguy33 will become famous soon enough
Send a message via AIM to Ryguy33
speakers
ok so i installed my new radio and it sounds a little different i think i might have wired it wrong. so my question is on the door speakers there is the tweeter that sounds fine and is the bottom door speaker supposed to be muffled/ a bass?
Mods = stuff to make me take corner faster
Old November 11th, 2009, 03:28 PM   #2
2003 Mustang GT
shnouz is on a distinguished road
turn the bass down in the door speakers/ if you have a 460 fade the speakers to the back 6x8s for bass output if you dont have subs
Old November 11th, 2009, 03:29 PM   #3
2003 Mustang GT
the front doors are paper cones and do not handle the bass output very well especially with more power thru an aftermarket headunit
Old November 11th, 2009, 03:50 PM   #4
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Stock speakers are pretty shitty all around as far as bass goes. I have 2 10" rockfords and I just filter all the bass out of the regular car speakers. All the higher tones go through the stockers, all the bass goes through the subs.
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old November 11th, 2009, 04:12 PM   #5
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is a jewel in the roughDolbs4082 is a jewel in the roughDolbs4082 is a jewel in the roughDolbs4082 is a jewel in the rough
He's correct, they just cannot handle it. my car has the mach 460 with an alpine aftermarket digital media center (cd playerish) and an alpine 15" type R sub, i've got my bass settings at -5 and treble at +7 with it faded to the rear to -3. Music is crystal clear, and with that 15" it def hits the lows even with the bass turned wayyyyy down haha
MM + Cleavage member #22
Old November 11th, 2009, 04:14 PM   #6
Dolbs4082's Avatar
2005 Mustang GT
Also, if you happen to switch 2 of the wires around (positve vs negative) then it may cause it to be muffled but more then likely it will just pop due to the reversed polarity. so that may be an option as to why their not sounded correct?
Old November 11th, 2009, 08:01 PM   #7
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
i think thats what i did because the tweeters sound fine but the big ones below it sound muffled.
anyone have a wiring diagram for the wires?
Old November 11th, 2009, 08:04 PM   #8
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
BUILD 2 IN PROGRESS
Old November 11th, 2009, 08:05 PM   #9
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
did you cut the plug off and wire them up or did you just tap into that male plug?
BUILD 2 IN PROGRESS
Old November 11th, 2009, 08:12 PM   #10
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
umm im not sure what your asking...i just got the harness and connected all the wires that were the same.
Old November 11th, 2009, 08:33 PM   #11
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
did you replace the speaker or did you replace the radio? either way, if you purchased the harness for either one and wired them up correctly then you shouldnt be experiencing any problems.
if you just replaced the radio then adjust your settings to your liking as mentioned above. if you replaced a speaker then try switching the two wires around to see if that makes any difference in sound quality.
BUILD 2 IN PROGRESS
Old November 11th, 2009, 11:29 PM   #12
Ryguy33's Avatar
2002 Mustang Gt
3 seconds......flat
yea it was just the radio..is there any specific settings that its supposed to be at?
Old November 11th, 2009, 11:31 PM   #13
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
not really, just play around with it until you get some sound that is pleasing to your ears. I could tell you a setting that I like and someone can do the same but its not your ears so what we like you may not.
BUILD 2 IN PROGRESS
Old November 12th, 2009, 01:49 AM   #14
mxnate116's Avatar
88 mustang GT
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
do you have loudness or bass boost turned on? thats a sure fire way to get crappy sound
Old November 12th, 2009, 11:32 AM   #15
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
try setting your hpf a little higher,that may help,unless you want bass or mids coming from your door speakers then you need some components
Threads Similar to: speakers
speakers riddlee josh Audio/Video 13 July 8th, 2008 12:06 AM
speakers riddlee josh Audio/Video 0 July 7th, 2008 01:26 AM
Speakers! soccerboy08 Audio/Video 23 December 9th, 2007 12:18 AM
Speakers 40thANVGT 96-98 2 June 18th, 2007 01:15 AM
Speakers went out? HessiaN257 99-04 5 April 7th, 2007 11:04 AM
