white faced gauges
Old February 24th, 2007, 05:02 PM   #1
smokiebear911 is on a distinguished road
white faced gauges
I bought some white faced gauges and have everything installed. I am having trouble trying to find where to run the power wire. I want to run it to the headlight wire so they will turn on with the lights. Does anyone know what color the wire is to look for?
Old February 24th, 2007, 05:08 PM   #2
raceruler03's Avatar
2000 mustang gt
raceruler03 is on a distinguished road
Send a message via AIM to raceruler03
you could just run it down to your fuse panel through the dash
Old February 24th, 2007, 05:28 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
here you go if you want to make it clean.
FORD, MUSTANG, 2000, Parking Lights+ Brown wire. 26 pin plug pin 7
The GEM (Generic Electronic Module) is located above the driver kick panel.
close
BUILD 2 IN PROGRESS
Old February 26th, 2007, 11:39 PM   #4
jabrennan's Avatar
jabrennan is on a distinguished road
the positive wire(red) for your gauge kit will need to be attached to the thick grey wire which is in the middle of your headlight cluster.....if you unbolt your headlight bar and detach the wire cluster you can push out the grey wire and wrap your positive around the ring terminal...i also secured it with some electrical tape to make sure it wouldn't come loose...then you can put the ring terminal back in and hook your headlight bar back up....the negative wire will need to be attached to a good ground...there is a big steel bar behind your cluster that will work nicely....here is a link to better instructions in case mine don't make sense
http://www.americanmuscle.com/mustan...es-how-to.html
Threads Similar to: white faced gauges
white face gauges yojoe600 99-04 12 October 18th, 2007 06:39 PM
White face gauges 2000mgt 99-04 4 August 8th, 2007 05:44 PM
White face gauges... fastford3388 5.0 Mustangs 4 June 8th, 2007 06:00 PM
white gauges o3gtdgs 99-04 4 December 27th, 2006 12:41 PM
White Gauges o3gtdgs 99-04 8 October 4th, 2006 01:09 AM
