Left Blinker?
I'm assuming this is the right spot.
My left blinker when turned on flashes very rapidly as if a bulb is blown. All bulbs are working. The right one is fine as well. What could be causing this? I was thinking maybe a relay? |
Honestly, it may not be just the blinker bulb. If ANY light on that side goes out that will happen. Could be a back up,brake, blinker, whatever.
but thats the thing, they all work fine. that is why im just so completely clueless.
can also mean that one is GOING out. if the electricity isnt flowing perfect from start to finish, it can do that.
ive replace all the bulbs already, so where should I start from there?
Change your relay and your blinker fluid then you should be good
where are they located and how do i go about doing this?
Sorry for all the questions, Im new to this stuff and trying to learn. |
what kind of car you running?
95 base model with a 5.0 swap.
2000 Kona Blue GT Vert
the flasher is located on the back of the fuse panel... It is a quick and ez swap... If you have the wrong kind of bulb it will also flash fasat... The backup bulb has nothing to do with the flash rate of the turn signals... check the front bulb, the dash bulb, and the rear bulbs... a heavy duty bulb will make it flash faster... Here check this out..
TROUBLESHOOTING BASIC TURN SIGNAL AND FLASHER PROBLEMS Hope it was helpful.. reps if it is... Thx!
Maybe you guys can help me with a similar problem. 2000 base V6. My blinkers on the right work fine with no speed problem, however my left blinker only blinks rapidly in the back and not at all in the front.
#12 | |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
#13 | |
Your Mom's Favorite
2007 Mustang GT
Your front bulb is burned out. Replace it.
No offence, but I have good common sense and that was the first thing I checked. I've since replaced the headlights all together and still experience the problem.
Your Mom's Favorite
2007 Mustang GT
It's probably the socket or cut wire then, given the age of the car...did you try a second bulb when you replaced it? I've had bulbs that either didn't work or blew out immediately after installed on my beater.
EDIT: After rereading your post...what did replacing the headlights have to do with your front blinker?
Check your Blinker Fluid
2001 3.8 V6
Hi,
I think your car is young enough to still have thermal blinker switches. The higher the current, the faster they blink. First, check ALL of the light bulbs to be sure they are the correct parts. Realize the the slow blinkers might be the problem and the fast ones are correct. So check all of them all over the car. Then you have to get out a current meter and test the current in the right and left blinker circuits and hope to find a friend with a similar car to know what reading is right (or how fast their's blinks). Unfortunately, you might have a short in the blinker wiring and God only knows how to track that down. If your car has ever had trailer light wires attached, start there!! There is no such thing as "blinker fluid" they are jerking your chain there ![]() When you pull out the bulbs, look into the sockets for any sign of corrosion or burning too. Hope this helps... Gandolf |
#18 | |
Blinker Fluid [BF-01] - $8.99 : KaleCoAuto, Hard to find automotive items!
#19 | |
2001 3.8 V6
![]() There are many good electrical contact cleaners and "lubricants". Since automotive lives in the 12V world, many contact lubricants used in say the 120VAC electrical world will not work well. Just cleaning with Purell (Yes, that swine flue hand cleaner (jellied alcohol)) will do wonders. Any pure light silicon oil will be fine if rubbed on and rubbed off to leave a very thin film will do great too to prevent water and dirt from messing with the contact. Don't use WD-40 or anything stupid there. The mechanics of the socket do 95% of the work anyway to make the contact. If it is all bad, replace the whole socket. BTW - I am reminded that a poor contact causing high resistance is more likely than a short. So look very hard at the "slow" blinking circuit!! A high resistance causing slow blinking is more common than an oddly fast blinking circuit. Gandolf |
Does this mean that the engine oil bypass kit I bought from there is junk too?
Threads Similar to: Left Blinker?
| Blinker problem | icon | Audio/Video | 6 | October 29th, 2008 10:21 PM |
| Left hand blinker | mustang fanatic | 2005 - 2010 | 35 | April 4th, 2008 04:12 PM |
| blinker and lights help | emgjsdk1 | Audio/Video | 0 | March 6th, 2008 04:57 PM |
| Issue With Blinker | G.T. Rags | 96-98 | 12 | December 30th, 2007 02:39 PM |
| Blinker | orbface9 | V6 Mustangs | 12 | December 13th, 2007 11:54 AM |
