radio
Old March 19th, 2007, 04:44 PM   #1
indign is on a distinguished road
radio
Hello,
i have an 04 mustang with the mach sound system (which blows ass).
what i want to do is keep the stock head unit and speakers all working but i want to add a sub in the trunk.
Is there a way to go about doing this without destroying the way my system is setup now, i looked around for a wiring harness or anything that might help but there is nothing.
any help would be great
thanks
cory
Old March 19th, 2007, 05:45 PM   #2
AVICJR is on a distinguished road
You will need some kind of factory OEM integration processor like this SLD 44
http://www.phoenixgold.com/2004/linedrivers.html
Manual.
ftp://208.187.38.55/Phoenix_Gold/Man...D44_Manual.pdf
There are other brands, but I know this one is going pretty cheap right now.
It taps into the speaker wires and then you can send an RCA out to amp for sub.
Old March 19th, 2007, 07:03 PM   #3
ok that makes sence but one problem i lose the front or rear speakers depening on which lines i cut to splice into this device.
Old March 20th, 2007, 12:04 AM   #4
No you won't, as you are only tapping into them.You can find some "t-taps" at a local automotive or hardware store. Look in the electronics dept. You just clamp into the already existing wire and send a new set of wires to the SLD 44 (or whichever processor you decide to use).
Old March 20th, 2007, 01:27 AM   #5
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
in the trunk in the middle of the amps you should see wire coming out, look for 2 BLACK/WHITE wires and 2 BLACK wires. The BLACK/WHITE wires are possitive and the BLACK wire are negative. It doesnt matter just hook up the WHITE and GRAY wire to the each one of the BLACK/WHITE wires and hook up the WHITE/BLACK and GRAY/BLACK wire to each of the BLACK wires and you should be good. Let me know if you need anything else.
Like AVICJR said just go to any audio shop and get a line out converter and then just tap them in, strip the protective sleeve around the wire back and then take something and poke a hole through the wire then you take the line out converter that you baught and tap the solid colored wires into the BLACK/WHITE wire that is stated above and then the striped wires from the line out converter and put those through the BLACK wires, fold those wires around the wires that you stripped back and then tape them up and then you are good to go.
BUILD 2 IN PROGRESS
Old March 20th, 2007, 06:32 PM   #6
great thanks for the info, i actually found a decent amp that has a high line in so if all goes well i can just patch it in that way and forget about the line driver.
Cory
Old March 20th, 2007, 09:40 PM   #7
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you do not want high level input, you want low level input
BUILD 2 IN PROGRESS
Old March 21st, 2007, 06:03 AM   #8
ok then i will use the line driver.
one more question is there a remote wire anywhere i can tap into or should i just run a switched line.
Old March 21st, 2007, 02:01 PM   #9
It may also be labeled as the power antenna wire. It's blue or blue with white stripe.
Old March 21st, 2007, 03:47 PM   #10
awesome.
thank you everyone for your help, i think i am going to get one 15.
ill let you know how everything turns out.
cory
Threads Similar to: radio
Radio plove71387 V6 Mustangs 21 October 29th, 2007 01:00 PM
radio Black Five 0h 5.0 Mustangs 2 July 15th, 2007 05:15 PM
sirius radio? foxstang The Clubhouse 16 March 19th, 2007 10:40 PM
05+radio Ware Audio/Video 7 March 10th, 2007 12:08 PM
XM Sat Radio GTsetGO The Clubhouse 8 September 11th, 2006 12:00 AM
