Mach 460 died? - Page 2
Old June 19th, 2006, 11:45 AM   #21
Look Ma! My First Post!
Manny69v is on a distinguished road
New to the Mustang World but not to Sound Systems
If its not too late, It is going to be your Amps. So yea, it could be grounding out somewhere but it sounds as if the amps are fried. So yea you do get sound sometimes but I bet thats after you leave the car parked for a while... leaving the amp to cool. Then after 10-30 min. of use the sound cuts.
The Same can go for if only one speaker is cutting out... but if its only one speaker then the best is to just check the wiring first before replacing an amp.
Sorry, I can't help you with what amp to choose as I have not experimented on Mach systems yet. I hope this helps and gets to you in time.
Previous car: 94 Thunderbird with 900W Amp /Sub 1300W Amp / Speakers
Old June 24th, 2006, 11:15 PM   #22
94mustanggt is on a distinguished road
this is an old forum but yeah it was the amp the front eq underneath the head unit got one out of a 98 stang at the jusnkyard for $25.00
Old August 28th, 2006, 04:54 PM   #23
99svt3753's Avatar
1999 SVT Cobra
99svt3753 is on a distinguished road
see my other posts about the MACH 460
the AMP under the head unit is a 4ch used only for the "tweets" - 500hz and up .. which is why a lot of people complain about the sound quality of the MACH 460.
each amp in the rear deck run the 6x8s (6.5's for Verts) in MONO - 1 amp for the front two and 1 amp for the rear 2.
I've rebuilt plenty of MACH 460s lately cuz people try to add subs and cut wires not realizing the system isn't a typical PWR / GND / POS / NEG setup like all other car audio.
at least your prev. owner just put in a switch to add his subs instead of cutting all the leads goin to the rear amps
Tim
admin@midweststangs.com
Threads Similar to: Mach 460 died?
Jesus died for... Juggalo_X The Clubhouse 9 October 9th, 2007 07:16 PM
George Bush died! thisisme The Clubhouse 13 July 24th, 2007 01:02 AM
Top Gear presenter nearly died DanishStallion Multimedia 4 January 29th, 2007 12:30 PM
how many ppl died? itschristorres8 Videos 13 December 14th, 2006 01:24 PM
Car Just Died slingblade05 5.0 Mustangs 3 September 20th, 2006 02:34 AM
