Mach 460 died?
hey everyone i just bought a 94 mustang gt with the mach 460 stereo system it has a am/fm/cass no cd player i was driving down the road today listenin to the radio and it just stopped playing i have no clue what happened i mean i really like the mach 460 what can i do?? o yeah and the head unit is working fine its getting a signal from the anntenna and i tried a cass it didnt work either i think its an amp prob but im not sure
try checkin all the connections on the back of the radio first!
are there fuses under the steering column for the stereo i checked under the hood already
hell man to tell you the truth i dont know much about steareos
1999 Ford Mustang V6
does the radio power up but no sound?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
My 460's out too. The amps for the 6x8's are blown I think because they don't work but all the tweeter speakers do. Hmmm..
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!! Now... ...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition.. www.cardomain.com/id/po1snd_u |
It could be a blown fuse, a bad connection or blown amps.
Start by checking the fuses then check all the connections and if that doesn't work check to see if your amps are giving out power. Oh and xx9gt6xx if you only get highs from your tweets both of your amps are blown. You can replace the stock amps really easily but it is going to be like 400-550 dollars for the two amps in the back. I would reccomend an aftermarket amp. But warning, your system will most likely not give out the same amount of bass!! You might need to get a small extra subwoofer if you get a new aftermarket amp. |
hey everyone things for all your input, this morning i was looking under the steering column and noticed a switch mounted by the hood release i switched it on and the stereo worked again the previous owner must have installed it
hey everyone again my stereo stopped working again its not the switch that was installed that is to a glass break security thingy i checked all the connections behind the radio and all fuses under steering column and under the hood iono what the problem is i was just goin down the interstate and i just quit the head unit is fine and everything sounded perfect the it just stopped playing music no speakers work at all!
Get a friends stereo and hook it up to yours, I think it might be the deck. If it is just a cheap am/fm with cass the deck might have gone out.....
its the stock one, if it is out what is the best adaptor to use to hook up an aftermarket deck oyeah the hu appears to be fine getting a signal from the att n' everything so iono
hey again i figured out that it wasent my head unit i think now it is the power amp is it possible to bypass that amp?
Both of the amps in the mach 460 work sequetially so there is no true "power amp."
If you know someone else with the mach 460 or mach 1000 you can easily swap one of the amps and it should make a huge difference. Chances are that if one of your amps are blown, both are. |
what about the amp behind the head unit?
I think you are reffering to the head unit amp. Pretty much all modern head units have a very small amplifier but they are not anywhere near strong enough to power most quality speaker setups. That is why you have the extra amps in the back.
If that is blown your head unit wouldn't even work. |
ok that helps alot one more question. do you think it could be a loose connection somewhere or a bad ground because it will turn on and off randomly, plus im trying to find a head unit to try to use
If that is the case, you have a 95% chance that its a (or several) loose connection(s).
hey again everyone walmart had a sony xplod head unit with aux input for 89.99 and i was suprised to find a wiring harness that worked with the ford "premium sound system" i plugged it in to the back of the old radio connections and hooked up the new stereo and it sounded great. the guys at best buy and local audio stores said it couldnt be done with a mach 460, but it sounds just as good as stock and it took less than 20 min to install. o yeah and by the way the harness was only $9.99!
That's what I origionally thought it would be, good buy by the way! Good price and Xplod makes a good head unit but I am not one for the woofers.....
Don't blare it too loud!!!
wtf the system sounded perfect im going home from skool today and it cut off again wtf!!!!!!! anybody have any other ideas i guess it wasent the hu afterall
Threads Similar to: Mach 460 died?
| Jesus died for... | Juggalo_X | The Clubhouse | 9 | October 9th, 2007 07:16 PM |
| George Bush died! | thisisme | The Clubhouse | 13 | July 24th, 2007 01:02 AM |
| Top Gear presenter nearly died | DanishStallion | Multimedia | 4 | January 29th, 2007 12:30 PM |
| how many ppl died? | itschristorres8 | Videos | 13 | December 14th, 2006 01:24 PM |
| Car Just Died | slingblade05 | 5.0 Mustangs | 3 | September 20th, 2006 02:34 AM |
