best car audio? - Page 2
Old October 15th, 2010, 06:12 PM   #21
castine917's Avatar
95gt,67maro,05sti....
14.8@93,13.6@101,
castine917 is on a distinguished road
i agree. my system that was in t-bird sounded awesome. transfered all of it to my mustang and it was just ok. the one set up for my tahoe was in a different one of my mustangs and sounded like poo in mustang, in tahoe though it was best system i have had to date.
Old February 6th, 2012, 09:32 PM   #22
sarahsarahsarahh's Avatar
no mustang yet :(
sarahsarahsarahh will become famous soon enough
thanks so much for all your input!!!!
Old February 6th, 2012, 10:45 PM   #23
cici is on a distinguished road
Select a car dvd monitor with high-level outputs; if you plan to add an amplifier later, choose a stereo that also has low-level outputs.
Old February 13th, 2012, 10:11 AM   #24
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
To get good quality, loud sound you need a good signal. The signal from the head unit isnt the best. To get a good signal for loud,clean sound you want to run external amps. I powered some crappy 6.5" speakers I got $30 off an amp an they sounded great. Certainly not the best but they were plenty loud and the sound was clean and crisp even at full blast, not that i ever needed it there, since I dont like making my ears bleed.
Old February 18th, 2012, 10:38 PM   #25
Look Ma! My First Post!
madridlv70duece is on a distinguished road
image dynamics are pretty good. always good. i just bought a stang with all boston acoustics though ;p
i have a 10 inch diamond audio tdx to put in with it
Old February 21st, 2012, 02:47 PM   #26
mangogirl205's Avatar
2001 V6 Mustang Vert.
mangogirl205 is an unknown quantity at this point
Off the topic a little bit..sorry..should you over power or under power your speakers?
If the speakers are 65rms @ 4ohm, would an amp rated at 50rms @ 4ohm work?
BBK CAI,K&N FILTER,MAGNAFLOW TRUE DUAL EXHAUST,CUSTOM MID PIPES,TB SPACER,MSD IGNITION,MSD 9MM WIRES,17x10 TSW RIMS,FALKEN TIRES 245/FRONT/255 REAR,MAC HEADERS,3.73 GEARS & T-LOK(need to install)
10000K HIDS,CF SPOILER & VISUAL GOODIES
Old February 21st, 2012, 02:59 PM   #27
Shelby's Minion
RZNCAIN's Avatar
2007 Mustang Shelby GT
(Mach1) Sept. '10 ROTM
RZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud of
more quality>more loud
Sponsored by Specialty Coatings
Car Salesman Club- Founder
2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked
1988 LX 5.0- Umm...Driver?
Old February 21st, 2012, 03:07 PM   #28
What would happen If I used this set up:
Speakers 65rms @ 4ohm, Amp rated at 50rms @ 4ohm
Old February 21st, 2012, 04:03 PM   #29
Blown 03 GT
Mangogirl, your not over powering the speakers but your leaving something to be desired on the table. Sounds like these are small speakers from the rating, if they were bigger, heavier speakers, like subs, under powering them could hurt the performance more if the speaker doesnt move enough. With your speaker, 6.5"? It shouldnt hurt much.
Old February 21st, 2012, 04:32 PM   #30
Yeah,the speakers are 6x8 Rockfords. I have RF components that are 100rms and a RF amp rated to the exact tee as well as with some RF subs matched with an RF amp matched perfect.
My components are nice and loud but my RF subs are rated 500rms each and still the bass is loud so I want to make my door and rear speakers louder..lol.
I put lower rated speakers in my door & rear because I had components in some custom kick panels.
I don't have the RF amp yet for my door/rear speakers...but the only amp I can find by RF have 50rms @ 4 ohms. I want to match them perfect..maybe I should keep looking to find the perfect amp.
Old February 21st, 2012, 04:37 PM   #31
Could I use this? Just to power the 4 speakers. It's rated 10rms over the speakers.
Rockford Fosgate
Old February 21st, 2012, 04:41 PM   #32
Nevermind...I don't see any RCA's..lol
Old February 22nd, 2012, 04:39 AM   #33
castine917's Avatar
14.8@93,13.6@101,
Finding an exact match on advertised RMS is unlikely. You want to get as close as possible though and preferably with manufactures that are accurate on their ratings.
Old February 22nd, 2012, 02:21 PM   #34
Blown 03 GT
Youll be safer being under rather than over the rating. Like a said, unless your dealing with subs I wouldnt worry bout being under slightly. RF is a good amp for the money.
Old February 25th, 2012, 01:35 AM   #35
Novanutcase's Avatar
2003 GT
Novanutcase has a spectacular aura aboutNovanutcase has a spectacular aura aboutNovanutcase has a spectacular aura about
SSS,
Although it will be more than your budget, I've heard this system in at least 5 different cars and it sounded pretty damn good in all of them. Not audiophile but very good SQ and SPL for the money!
Alpine CDA-117/Head Unit - $349.95
Alpine PDX-5/5 channel Power Amp - $599.95
Alpine PXA-H100 Imprint Audio Processor - $149.95
Alpine SPR-60 6 1/2" Coax 2 way speakers - $179.95/pr
Image Dynamics IDQ10 D4 10" subwoofers - $219.99 each(I'd go with 2)
Total - $1,719.78 plus tax
If you can mount the SPR-60's in your kick panel instead of your door it would be good. If you can find an aftermarket kick panel that angles the speaker towards the dome light even better. If you really want to get tricky and budget permits you could run the SPR-60C which is the same as the SPR-60 but the tweeter is separate. If they fit you could place the tweeters in the stock spot where the mirrors are attached to.
If you have the room I would mount the subs in your rear package tray firing at your back glass with an enclosed box for each one.
Just as important as all the other components is WIRING! Forget all that cheesy, chinese bullshit like monster cable and the such. Pure trash. Go to a professional audio store if you have one in your area or, if not, online and try and find a roll of either Canare or Mogambi cable. This is the same stuff they use in TV studios and most all other professional audio applications. Best part is it's actually CHEAPER than the chinese crap. The only part that will need to be shielded are the cables going from pre-amp outs to the amp itself.
After all is said and done for components only, including wiring, you're going to drop about $2k but you will have one BADASS sounding system!!
This is the system going into my Nova build:
Highs and Mids - Image Dynamics Pro Full Size Horn Loaded Compression Drivers under the dash
Mid Bass - 18sound NMB420 8" or B & C 8NDL51 in the kick panels
Sub - Morel Ultimo SC10 10" in a sealed enclosure. I'll have 2 mounted on each side of the car firing into the back glass.
Head Unit - Pioneer DEX-P99Rs
Amplifier - JL Audio HD900/5
Still trying to figure out the best crossovers for my application.
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles
Threads Similar to: best car audio?
Car Audio Basics TurboLX Audio/Video 8 July 21st, 2011 07:58 PM
car audio. mach help! 94stang Audio/Video 8 July 17th, 2008 06:59 PM
Car Audio Wiring - Need Help! ChrisxF Audio/Video 6 June 6th, 2008 01:45 PM
Ok Need Some Car Audio Help Here mixedbreed02gt Audio/Video 4 October 6th, 2007 10:32 AM
