LinkBack (1) | Thread Tools |
#1
Alarm won't go off
I have an autostart/alarm thing on my car, whatever you call it...it locks, unlocks, starts and stops the car, but for some reason the alarm doesn't go off anymore when you try to open the door when its locked. I think this may have started happening after I left my lights on and killed my battery, I'm not sure though.
Is there any way to reset an alarm system or something? just something to make it act normal again... |
Moderator
When you hit the lock and unlock button does it chirp at all or your horn honks? Is your led blinking or constant when you arm the car? If it doesnt chirp or the LED is constant then the alarm might have went into valet mode. What brand do you have?
![]() ![]() BUILD 2 IN PROGRESS |
yeah it chirps when I lock or unlock it. the led blinks very fast, like it always has. it's an Autostart NAHRS5304.
anyone..?
no dice, eh?
Moderator
who installed it? i would take it back to them so that they can check it out. There is no program for door triggers. Even if the battery died it will still work, the only other thing that I can think of is that somehow during the whole battery dying and changing that your door trigger went bad (which I dont see how it would) but it could be a possibility.
By the way what year is your ride?
Moderator
Alarms systems dont have resets. You have to actually program all the functions into the brain and then the only way to reset it is to program it manually reset it via the valet switch.
I don't know who installed it...it was already on the car when I got it.
It's a 94. where might the valet switch be? |
#9 | |
![]() New block with forged internals running 16psi, tuned by Lasota Racing Too many mods to list... 3.73's and Truetrac Finally Done!
hmm...i'll see what I can find, thanks.
we usually install the valet switch under the driver dash or in the drivers kick panel.
2002 Mustang GT. 18" Shelby Torque Thrusts w/Mach 1 lip, Cobra Front End, Short Throw, K&N filter. Nothing impressive as of yet, but I'm working on it. |
I know this is an old topic but I need to bring it back...
A little while ago, I found my valet switch, and I noticed that one of the two wires going to it had come undone. so i soldered it back together, and the alarm seemed to be working better but it still didn't go off when I just tried opening the door while it was locked, I had to actually open the door with the alarm armed for the alarm to go off. So i was playing around with the valet switch trying to get it back to working like it used to, but in the process I somehow completely fucked it up and now it doesnt chirp at all, ever. command start doesn't even work, the lights flash but the car doesn't actually start. all it does is it still locks and unlocks with the remote but that's it. is there any certain way that i'm supposed to press the valet switch to get it to work again? like do i have to hold it for a certain amount of time or some kind of pattern? please help!! |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/19423-alarm-wont-go-off.html
| Info.com - 2006 ford mustang won't start remote doesn't work - www.Info.com | This thread | Refback | October 12th, 2008 02:19 AM | |
Threads Similar to: Alarm won't go off
| alarm | efulton95 | 94-95 | 2 | October 31st, 2007 11:53 PM |
| Do i have an alarm? | MustanG_guy17 | V6 Mustangs | 7 | August 18th, 2007 02:19 PM |
| Car alarm | locknest | Audio/Video | 5 | February 18th, 2007 11:52 PM |
| alarm?? | jat | 2005 - 2010 | 8 | February 9th, 2007 09:50 AM |
| Alarm | 232stang | All Other Vehicles | 2 | November 15th, 2006 02:31 PM |
