more bass?
Old April 30th, 2006, 07:06 PM   #1
94mustanggt is on a distinguished road
more bass?
hey guyz i have the mach 460 i put a new head unit in a sony xplod one it has 1 set of preamp outputs on the back my question is when i put in the new hu the subs that come stock arent as loud as they were before which sucks so is there a way i could get the subs that are in there now to be loud like the stock hu or should i run rca cables from the new hu pre-amp out to an amp then put a sub in the back?
Old April 30th, 2006, 07:23 PM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
We had a few people with the same problem and it turns out that they didnt have power to the factory amp.
Old April 30th, 2006, 09:55 PM   #3
there is power to the rear amps its just not as loud as it used to be
Old April 30th, 2006, 11:33 PM   #4
Have you gone thru the equalizer settings and fine tuned everything? Most aftermarket head units have a "loud" feature. All it does is give you about a 30%increase in volume and bass. Have tou messed with this feature yet?
Old May 1st, 2006, 10:51 PM   #5
yeah its a sony xplod one i turned the low setting up as loud as it will go
Old May 2nd, 2006, 01:01 AM   #6
I know Sony has the "loud" feature and if Im not mistaken it has 3 levels too.
Old May 2nd, 2006, 06:19 PM   #7
it lets u turn the low up to 3db i read the book maby i missed something i guess i need to read up on it
Old September 12th, 2006, 12:06 AM   #8
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
Called D-bass actually gut I think it's more of a problem with the voltage from the RCA's.factory stuff would usually run a lower line out voltage than an aftermarket h/u but I know some Sony h/u have a relatively low line out voltage.See if you can adjust the gain on the factory amp.You probably can't but see any ways,then move onto the option of running RCA's back to the amp but I'm pretty sure there are no RCA inputs on that factory amp(all wires i think) Good luck because low bass sucks unless it's a 30hz type of low!
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Threads Similar to: more bass?
Bass package Kinshen Audio/Video 8 August 30th, 2007 05:40 PM
Bass in a Mustang TheStangStillShines V6 Mustangs 108 August 11th, 2007 01:59 AM
Very Low Bass on subs Clayhistorian Audio/Video 4 June 17th, 2007 07:42 PM
never can have too much bass. WAVEBYE Videos 3 January 15th, 2007 04:41 PM
Bass taken little too far ? DanishStallion Multimedia 1 October 18th, 2006 11:43 PM
