Look Ma! My First Post!
door panel removal?
MY COUSIN DRIVES A 95 GT, AND HE WANTS ME TO REMOVE THE DOOR PANEL FOR HIM IN ORDER TO GET THE BROKEN OFF KEY OUT OF THE LOCK. I HAVENT SEEN A SEARCH FEATURE IN THE FORUMS, SO IF SOMEONE KNOWS OF A PREVIOUS TOPIC ABOUT THIS OR IF YOU JUST WANT TO POST HOW TO DO IT, THAT WOULD BE GREATLY APPREACIATED. THANK YOU
Moderator
the whole piece that has the switches on it will pop off, you will have to unscrew the connection to the switches to remove, then you will notice 2 phillips head screws in the panel, remove them. Look at the very front of the door panel to the bottom (towards fender) and you will notice a little push pin there, remove. remove bezel surrounding door handle (pops off) if you have a mach system you will have to take the grill off of the tweeter and unscrew the tweeter pod w/o Mach then just take the sail panel off. Now just grab the panel, pull up, then out and your done.
![]() ![]() BUILD 2 IN PROGRESS |
Threads Similar to: door panel removal?
| the door panel | stinglikeastang | V6 Mustangs | 26 | January 8th, 2009 12:23 PM |
| sail panel and a pillar removal? hellpppp | energiesource | 99-04 | 2 | September 15th, 2007 02:55 AM |
| Removing 94 door panel | Murderjetz | V6 Mustangs | 18 | July 21st, 2007 12:08 PM |
| door panel | cam08 | 99-04 | 5 | June 23rd, 2007 01:32 AM |
| Door Panel Removal | MNmustang | Audio/Video | 5 | November 12th, 2006 03:13 PM |
