Bass cutting in & out in front speakers of Mach 460 syst
Old May 4th, 2006, 10:38 PM   #1
Look Ma! My First Post!
varnamsgirl is on a distinguished road
In my 98 GT, the sound from the front door speakers cuts in and out. I am not sure if the speakers are stock or aftermarket. Has anyone had this problem, and, if so, do they have any suggestions on how to remedy it?
Old May 4th, 2006, 11:30 PM   #2
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
u could try replacing the amp... it could be faulty or loose connections on the wires, don't have that stereo in mine so im free shootin
Old May 8th, 2006, 01:11 PM   #3
ckthecerealkiller is on a distinguished road
I have an aftermarket amp and my speaks will do the same thing. It's something to do with the electronics in the front of the car but I never really looked into it.
Old August 28th, 2006, 04:58 PM   #4
99svt3753's Avatar
1999 SVT Cobra
99svt3753 is on a distinguished road
they are aftermarket speakers and most likely 4ohm .. stock speakers are higher and the amps will clip and cut out with aftermarket speakers or deck
the front amp (4 channel made to run the 4 smaller "TWEETERS" from 500+ hz can't handle the aftermarket setups properly) is a modulated system and your aftermarket amps should NOT be run from the outputs of that unless you turn your amp down or use the HI-LEVEL inputs.
just trim the base level out a bit if you need to turn it up over 1/2 way or install a non-pol resister to take the ohms back up to 6-8 ohms.
admin@midweststangs.com
Threads Similar to: Bass cutting in & out in front speakers of Mach 460 syst
Mach 460 speakers to factory system? lbstang Audio/Video 1 August 30th, 2007 11:24 AM
Mach 460 Speakers Not Working on One Side of Car fulci Audio/Video 1 July 2nd, 2007 09:29 AM
mach 460 speakers? BrightWhite98GT Audio/Video 3 June 13th, 2007 10:09 AM
Mach 460 door speakers doubledutch86 Audio/Video 4 July 25th, 2006 07:18 PM
