headlight install
I just got dual halo projectors for my car today and i need some help if nebody is willing. I was just wondering how i should wire the 3 LEDs and the halo rings?
wire em into the 12v+ that goes into the back of each turn signal marker that is always on when the running lights are on. not the one that pulses..obviously
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
[8MINUS2]
Or,
wire them to a switch so you can have full function of them.... Edit: substitute function for control, damn 1:39am writing papers due tomorrow morning
#4 | |
¡ʇsnq ɹo uʍop ǝpısdn
get a test light? pick up a tubed bulb from an auto store for $1 and then set it between the wires and see if something magical happens
Haha, drr im not thinkin. Ill just use a voltage tester. Please excuse my absent-mindedness.
How should i go about connectiong the wires? Theres three seperate positive and negetive wires. I guess i can just tie them into each other, but how should i connect them to the 12v wire?
MM's Database Error
with crimp connectors, or if u are too lazy to do that then twist the ends together and use electrical tape.
to hook em into the 12volt wire u can get connectors that do that i believe, or u can cut away some of the jacket and connect it to the wire, just make sure whatever you do that all bare wire and connections are covered good...you dont want metal touchin that power...
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
now that you guys are talkin about headlights i thought i might ask this questions...kinda silly .... you guys know where the headlight bulb goes in your headlight...well when you stick the bulb in theres sort of like a thin piece of like a silver glass right in front of it .... if i were to break that would the intensity of the lights be greater ???
Ok... I did some searching and i think the connectors ur talking about are called t-taps, they look easy enough to use b/c u dont have to cut the jacket away. thnx for ur help. Ill prolly have pics up tomorrow after i put them in if nebody wants to see.
#12 | |
not really in my opinion i guess so you wont stick a bigger bulb
MM's Database Error
its there for reflection, it would prolly make ur lighting worse. what it seems to do is that it reflects the light from the bulb back into the entire shiny housing which throws the light out in front of you spread out.
#15 | |
ok since were on the topic of headlights...i have an 04 and when sometimes when i turn on the lights the driver side one only lights up a lil bit but then if i flash my high beams it'll turn on sometimes and other times it'll turn completely off...any sugg on wat could b wrong?
MM's Database Error
wire problem, or maybe bulb isnt all the way in, do the general checks right around the socket and see for anything obvious. if it isnt anything like that, my guess would be a short somewhere along the line
hey man when you get it done can you send me some pics so that when I do mine I get it right.
we're like then an 's like and Im like :lala then we're like then Im like :award then he's like then everyones like you got then he's like I got Im like
I decided to have a mechanic do it b/c the headlight was a pain to get off and im very lazy and easily frustrated. Hopefully it'll get done saturday.
well do you think you could still take pics of where they're wired to?
Threads Similar to: headlight install
| 94-98 headlight help | Nick_Rapitis | V6 Mustangs | 12 | August 13th, 2007 08:29 PM |
| one headlight | Dj1123 | Visual | 13 | May 16th, 2007 07:02 AM |
| 06 headlight!!! | Ware | Visual | 1 | May 12th, 2007 07:16 AM |
| Halo projector headlight install. | GreenFaleen | V6 Mustangs | 47 | December 22nd, 2006 09:45 PM |
