fog light problem
Old May 2nd, 2007, 10:16 AM   #1
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
fog light problem
I bought an aftermarket halogen foglight kit. It came with everything needed (wireing, lights etc.) and I added nothing to it. I installed it very carefully becuase I am not comfotable messing with electrical in the first place. I followed the directings exactly and everything turned out fine. They have worked perfectly for about a month.
Yesterday, I accidently touched the backside of the switch housing when I was turning them off. It was hot as hell. So I looked at the back of the switch and the 3 wires were "fused" together. Obviously, they didnt fuse all the way through but they are all stuck together now from heat. The outside of the wire covers look burnt or kind of black like they were about to start on fire. I checked out the rest of the wires from the lights back and there is no other damage. Again, all the hardware came with the lights so I know I'm using the right guage wire and stuff. This makes me wonder if the kit came with undersized wire. Is this common? Do you think I need to rewire the whole thing? I was told that maybe just replacing the switch with a higher rated amperage would help. That doesnt make sense to me but like I said, I'm NOT an electrician.
Any advice would be very appreciated.
Old May 2nd, 2007, 10:18 AM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you need to buy a wire upgrade kit from Ford.
sounds like you ran too hot of a bulb and you melted your harness.
Old May 2nd, 2007, 10:27 AM   #3
JASonic's Avatar
iTrader: 20 reviews
It sucks becuase everything came in a box ready to install. It took alot of time for me to instal which is frustrating. so what you're saying is the morons who made this aftermarket light are selling it with undersized wires??? what a bunch assholes.
Old May 2nd, 2007, 10:32 AM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
nah.. there wiring is fine.
our stock stuff sucks is all.
it should have had a warning on the box about it.
Threads Similar to: fog light problem
Head Light and Tail Light Opinion Needed Laser Visual 8 January 2nd, 2008 02:16 AM
How you can change your dome light color. (light on roof) SonicStang Visual 25 March 23rd, 2007 12:39 PM
Courtesy light problem... D-Brow Audio/Video 5 March 14th, 2007 12:14 PM
OBDII CODE PROBLEM(MIL) LIGHT ON edwincamacho 99-04 0 February 27th, 2007 05:35 AM
Mach 1 signal light problem tony123 Classic Mustangs 1 June 12th, 2006 06:38 PM
