If you are having mach 460 problems
Old May 18th, 2006, 12:18 PM   #1
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
Alright i am posting this here from some info that i found out plus a problem that i had. My speakers where cutting out and i only had the tweeters up front. Everyone keeps saying it was the amps, swapped amps and nothing then i did some research and found out that the ground strap on the back of the fuse panel is for the speakers and the bolt that holds it in comes loose on alot of cars. So before you do anything or waste any money on new amps and what now check that ground wire attached to the backside of fuse panel in the car, mine was loose and fixed my problem with a couple turns with a wrench.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 18th, 2006, 01:41 PM   #2
JRuckas is on a distinguished road
bout time you posted that... good info tim
Old July 19th, 2006, 12:04 PM   #3
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
i'm having the same problems with my mach 460 in my 94 GT.. the right side will work most of the time but the left side rarely ever cuts back in.. i'll have to check this out..
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old July 19th, 2006, 05:49 PM   #4
B0mb3r645 is on a distinguished road
Send a message via ICQ to B0mb3r645 Send a message via AIM to B0mb3r645 Send a message via MSN to B0mb3r645
Same here, thanks!
"Look up!"
Old July 19th, 2006, 11:18 PM   #5
mustangdude100's Avatar
mustangdude100 is on a distinguished road
the same thing happens to me when i go over a bump
"i aint never had too much fun"
Threads Similar to: If you are having mach 460 problems
Fan Problems! Please Help Me! shaken'bake Audio/Video 2 July 20th, 2007 11:08 AM
Fan Problems!!! Please Help me! shaken'bake 5.0 Mustangs 5 July 14th, 2007 12:35 AM
2000 Mustang Mach 460 Radio Problems bushden Audio/Video 21 March 28th, 2007 08:25 PM
problems with my 91 9stang1 5.0 Mustangs 1 February 26th, 2007 06:55 PM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 01:58 AM
