factory gauges?
is there a way i can test my temp sender to see if its working? my gas gauge reads full all the time, the oil pressure works "OK", the volts gauge reads 9 or less(i tested it, its 12+ at the fuses), and the temp doesn't move at all!
![]() 1989 Chevy Blazer 4x4 1987 Ford Mustang GT 5.0/C4 1986 Monte Carlo SS 350/350 2008 Chevy Impala |
your thermostat needs replaced
no, theres a 160 in it. i changed the temp unit and its fine now. i also changed the oil press sending unit and that works, the new gas tank w/sending unit and that works. the only thing that still won't work right is the volts!
test
I have heard that you can test it by taking the wire off of the sending unit and placing a resistor, 100ohm or 200 ohm and then grounding the end to the block. You should be able to see a significant difference between grounded with a resistor, and without. As for the fuel gauge, I am going to bet your fuel sending unit is bad, about $116 at autozone. on the fox, the fuel pump and the fuel sending unit are seperate, but they both go into the fuel tank. I am getting ready to replace mine, I have done it on a few Fords in my time........... The old F150 pickup
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
well i replaced the fuel sending unit, that works, WOOHOO! i replaced the temp sending unit, that works,WOOHOO! i replaced the oil one too, when i'm driving or idling its fine, i have pressure. but when i come to a stop or in gear at a light or something it goes to 0!
Threads Similar to: factory gauges?
| factory 5.4 max horsepower | Darkside_03_GT | 99-04 | 3 | October 22nd, 2007 12:45 AM |
| Factory Warranty | j3susfr3ak | 2005 - 2010 | 32 | March 8th, 2007 09:11 AM |
| Factory Upgrades | oklahomastate8 | V6 Mustangs | 2 | February 11th, 2007 08:27 PM |
| Self or Factory? | bcp5008 | V6 Mustangs | 15 | October 2nd, 2006 02:35 AM |
| factory timing? | OneBad347Stang | 5.0 Mustangs | 8 | December 14th, 2005 08:30 PM |
