Power Antenna
I just got a power antenna, like the kind that only comes up when the radio is on. I realize the answer to my question might be in the instructions but I want to try to ask here before opening it in case it's doesn't work out and I need to return it...I don't know if they'd take it back after it's been opened?
anyway, my question is this...does it extend when I'm playing a CD in my deck? I only want it to extend for when I'm actually listening to the radio, I want it down when I'm listening to a CD. Does it know wether i'm on radio or CD, or does it just work from wether or not there's power going to the deck in general? |
MM's Resident Ricer
2006 Scion tC
13.001@113
my moms only does it on radio
cool. any idea how that works? I dont really get how it can just know when its on the radio and when it's playing a CD...
'98 Mustang
Curious where you got your power antenna?? Looking for one for my '98.
Thanks. |
Napa Auto Parts. No idea if you have those in the states....assuming that's where you are.
Moderator
if you have an aftermarket radio it comes with a seperate wire for the power antenna (blue). The way that it works is that when you switch from CD to TUNER the H/U outputs a 12 volt signal to the power antenna wire and that what raises it. Once you go back to cd the power is cut from the power antenna wire thus retracting it.
![]() ![]() BUILD 2 IN PROGRESS |
nice...
I had the crazy idea of having it completely manually controlled. Like instead of hooking it to the head unit, I would get it wired to a toggle switch in the ash tray area, so that I could manually bring it up when I want, stop it at the desired height. bring it back down a bit if i think it looks too high...you know what i mean? so that it doesn't need to be fully extended every time it goes on. |
Moderator
yeah, you could do that if you dont want it fully retracted out that way it doesnt look so damn tall like our stock ones.
Threads Similar to: Power Antenna
| antenna? | patwrecked | 5.0 Mustangs | 2 | March 15th, 2007 01:07 PM |
| Antenna | Massie02GT | 99-04 | 27 | February 13th, 2007 03:10 PM |
| New Antenna. | jeff | V6 Mustangs | 54 | January 8th, 2007 08:09 AM |
| cutting my antenna? | TheTechnical99 | Audio/Video | 10 | January 2nd, 2007 11:04 PM |
