Subwoofer Boxes
Old May 14th, 2007, 09:43 PM   #1
Tlord18 is on a distinguished road
Subwoofer Boxes
Hey guys, I am putting a system into my 1998 V6 mustang. The only hang up I have is the box. I am stuck between building one or buying one off ebay. I ordered 2 Kicker Comp VR 12s and I was wondering does anyone have 12 inch subwoofers in their mustang, and if so, what are the dimensions of your box. I found out the hard way that the mustang has a small trunk and I want to make sure the box will fit before i buy one. Thanks a lot.
Old May 14th, 2007, 11:53 PM   #2
AVICJR is on a distinguished road
The easiest way to put a box in, IMO is to disassemble the back seat, and put the box in through there. It gives you more width and height for clearance. My box is 14" tall.
Old May 15th, 2007, 07:34 AM   #3
Subwoofer Boxes
I need the full dimensions of the box, aka length x width x height if you dont mind.
Old May 15th, 2007, 07:40 AM   #4
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
I have a box that was made for my kicker comp vr 12's by kicker. When I get home this evening I will measure it out for you. Just note that each sub is eclosed from the other sub. Go to kicker's website and get the recommended airspace for the subs.
Old May 15th, 2007, 07:41 AM   #5
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
fill the box with cotton as well...
Old May 16th, 2007, 12:48 AM   #6
Re: Subwoofer Boxes
The reason I didn't post the size is because every sub performs optimally in a different internal volume enclosure usually calculated in cubic feet. I have one sub in a 1.8 cu. ft enclosure, outer dimensions=14"x21.5"x14". I added the size of my box for reference. Again, find a box that is no taller (height) than 14 inches and you should be good.
Threads Similar to: Subwoofer Boxes
help with subwoofer orlyr21 General Tech 6 March 5th, 2008 05:47 PM
torque boxes baine21225 5.0 Mustangs 6 September 28th, 2007 10:38 AM
SUBWOOFER RATTLES SOMETHING IN 02 3.8L emgjsdk1 V6 Mustangs 23 August 20th, 2007 06:23 PM
subwoofer help Ticket-Me-Yellow V6 Mustangs 7 July 18th, 2007 01:56 AM
Mounting subwoofer boxes to trunk floor 98 stang Ionstorm Audio/Video 1 September 15th, 2006 09:08 PM
