Courtesy light
Old May 24th, 2007, 07:44 PM   #1
D-Brow's Avatar
2001 Mustang V6
16.49
D-Brow is on a distinguished road
Send a message via AIM to D-Brow
Courtesy light
do the 01 mustangs, it's a v6 if it matters, have a switch in the door for the courtesy light, or do they have a sensor like some of the newer cars?
Old May 24th, 2007, 10:32 PM   #2
D-Brow's Avatar
2001 Mustang V6
16.49
Re: Courtesy light
i only ask this because my courtesy light isn't working right. i had to take the bulb out because it stayed on all the time...does anyone know how to fix this?
Old May 25th, 2007, 10:46 AM   #3
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
sounds like one of the door triggers that registers the door being closed is broken so it thinks the door is open all the time which keeps the light on. see if the little pin in either door has popped out or snapped off entirely.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old May 25th, 2007, 01:15 PM   #4
D-Brow's Avatar
2001 Mustang V6
16.49
is the pin obvious to see, because when it comes to mechanics i suck to be honest...
Old May 25th, 2007, 02:41 PM   #5
Yea its quite obvious. look in your door jam where the hinges are and it will be on the door itself. there should be a pin that can be pushed in and will pop back out. this registers whether or not the door is closed.
Old May 25th, 2007, 10:54 PM   #6
D-Brow's Avatar
2001 Mustang V6
16.49
ok, i didn't see any little pins, it is night time right ow, so i'll check again in the afternoon tomorrow.
Old May 26th, 2007, 12:57 AM   #7
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
there is no pin like that in our cars...maybe they are in the pre-99s but ours do not have those pins...my light stays on every now and then too, not sure why, it usually goes out eventually. if it doesnt i just take the battery cable off for a lil bit and then put it back on (resets everything) and it works fine again.
SCT Mass Air Flow Sensor $200
Old May 27th, 2007, 01:11 AM   #8
hmm didnt know that. i assumed it would be the same for 99+ as well. still it sounds like its an issue with the mechanism that determines whether the door is closed or not w/e that happens to be.
Threads Similar to: Courtesy light
Head Light and Tail Light Opinion Needed Laser Visual 8 January 2nd, 2008 02:16 AM
LED courtesy lights Kuro 2005 - 2010 1 June 27th, 2007 04:52 AM
How you can change your dome light color. (light on roof) SonicStang Visual 25 March 23rd, 2007 12:39 PM
Courtesy Lights Won't Turn Off Username Audio/Video 5 March 14th, 2007 12:26 PM
Courtesy light problem... D-Brow Audio/Video 5 March 14th, 2007 12:14 PM
