Passenger window switch problem
On my passenger side, I can't lower my window. I have to use the driver side controls to do so. However, I can bring the window back up with the passenger side controls just fine. So, I'm pretty sure the motor works. I've taken the panel off and looked at it and it looks fine to me. I don't have a multimeter or anything, so does anyone have an idea? This isn't that big of a deal but it's something I'd like fixed.
1988 Mustang LX Turbo
check the wiring and see if it isnt hacked or the switchs could be no good
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
It worked fine when I got the car and then quit all of a sudden.
it's all good.
Oh, I hope I didn't suggest it's working now. I meant the fuses are good. Sowey!
Yeah, i'm having the exact same problem. I can roll it down with the drivers side but i have to roll it up with the passenger one. If you find out what your problem is the let me know. I'm probably going to get it looked at soon, doesn't matter much its just annoying.
Oh, well, I can roll it up on both sides no prob.
SVTfocus, F250
well if it works both up and down then your switch must be bad.
i dont think there is seperate fuses for up and down on each door to each switch. oh and just a heads up the switches are only 11bucks from 50resto.com either side |
#10 | |
89 GT
Threads Similar to: Passenger window switch problem
| Passenger window does not want to go down | dgt_mustang | V6 Mustangs | 7 | October 13th, 2007 03:03 PM |
| Re-Gluing The Passenger Window..... | lwhitetrash88l | General Tech | 11 | September 26th, 2007 12:19 PM |
| rpm window switch. | mustangrebuilder | 2005 - 2010 | 0 | September 18th, 2007 07:37 PM |
| Passenger window leaking......help? | lwhitetrash88l | V6 Mustangs | 14 | August 8th, 2007 12:04 PM |
| window switch | barksdaleammo | General Tech | 31 | May 23rd, 2007 09:33 PM |
