Driver Window Stuck Down :(
My first post..but I've been reading this forum for quite sometime.
First off, let me say I am a newbie when it comes to cars. I love my mustang to death but I don't have much expierence at all working on cars. The problem is about 3 days ago my driver side window all of a sudden won't go back up, it is stuck all the way down. The funny thing is it did this for a day back about half a year ago, then all of sudden worked fine again the next morning, however it hasn't fixed itself this time and probably wont. I noticed whenever I hit the button to go down it makes a click noise like it is working, but there is no click noise whenever I try to make it go up. Anyone have an ideas or solutions they can explain to me? I would really rather not take it to the dealership and pay for a bunch of stuff that I may not need. Thanks for any help, Matt |
give your inside door panel a few good whacks with your hand and wala it will go up. your runners either have binded and the window has slipped off them or the window actuator assembly needs to be lubed.
#4 | |
Well thanks for replying.
I just got done whacking that door panel and no luck. How can I lube the actuator assembly? Any other ideas? Thanks again |
#6 | |
I do hear it engaging when I hit down....but I hear NOTHING when I try to get it to go up.
#8 | |
How can I got about checking this?
#10 | |
Will do and give update soon....thanks.
Pulled off the panel and everything looked connected and in good shape? blahhhhh I want to get to the bottom of this.....anything else?
89 GT
Do you know how to use a test light or a multimeter?
if your car is older than a 2001 then window probablly is off track. before 01 ford just glued the window to the the tracking device. I took mine in to auto glass repair shop they replaced it with a whole new window for 200. they said they could fix it temperally with glue for 40 bucks but that it would come loose again shortly.
Sorry for the late reply...had some things to get done. It's a 2001 so its probly not off track. I've never used a test light or a multimeter before but I could prob figure it out..
MM's Database Error
i think it still has just come off the track prolly gonna have to take it to a shop since ur a newb to the whole workin on cars thing
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
I'M HAVING A SIMILAR PROBLEM WITH MINE EXCEPT MINE IS STUCK ON TOP. IT WONT GO UP OR DOWN AND I CANT HEAR ANYTHING. IVE POSTED A TREAD ON THIS AND "fogged306" TOLD ME HOW TO TEST THE WIRES...
HERES WUT HE SAID... I always use a test light because its just easier for me. I don't have the schematics for that car infront of me so this is going to be a little tough. First just test all the wires at the switch and see where you are getting 12v in... just make sure the key is on, of course. ok I found the up and down wire colors but not the 12v. but this should help a little anyway. drv.........yellow-up wht/blk-down pass.......wht/yel-up tan/blu-down "Ok well it still could be a lack of 12v in to the drivers side of the switch.. the way those switches are set up is called 5 wire reverse polarity. meaning when you push the switch up, it sends a positive out one side and a negative out the other, and vise versa for down. there are only 2 wires that are actual outputs on the switch and they go directly to the drv. motor. The motor will go in one direction when 12v is applied to it and reverse its direction when you flip the polarity of the wires... the switches are designed to do this without any need for relays so its really easy to diagnose. I also didn't mention in the last post that when you are testing for 12v out of the one wire, i.e. up.. test for ground on the down wire. do the samw when testing for 12v on the down wire, while pressing down on the switch." HOPE IT HELPS FOR YOU CUZ I DON'T GET IT |
Thanks for all the replys...ill try some of this and more tomorrow and if not just take it to the dealership
Matt |
#19 | |
89 GT
matloc, If you want I can tell you what to look for when you get the switch out and I can help you figure out where the problem is... I'll try to simplify whats written above a little also, those wire colors may not apply to your car depending on the year of your car. telll me the year and I'll verify the colors for you. |
its a 2001 v6 rained all day today so didnt pull it out and try anything....ill have to get to it tomorrow
Threads Similar to: Driver Window Stuck Down :(
| Window Got Stuck Again... | GatoStang | General Tech | 2 | November 29th, 2007 12:01 PM |
| 2002 mustang, stuck window | motorhead6776 | V6 Mustangs | 12 | September 8th, 2007 08:35 PM |
| window stuck | chris03gt | Modular Mustangs | 2 | July 15th, 2007 12:14 PM |
| Window Stuck Down | CNASHGO | Audio/Video | 5 | March 10th, 2007 11:08 PM |
| 93 gt vert right rear window gets stuck | PJZona | 5.0 Mustangs | 0 | October 12th, 2006 12:11 PM |
