How do I pull out my deck??
Old July 11th, 2007, 07:06 PM   #1
Murderjetz's Avatar
Murderjetz is on a distinguished road
Send a message via AIM to Murderjetz Send a message via MSN to Murderjetz
I'm trying to pull out my deck so I can hook up my amp into it, but I can't figure out how to pull it out....I've been playing around with a couple flat screw drivers, squeezing them into crevices around it trying to pry it out but it just won't budge.
it's not stock, it's a Pioneer DEH-2700 if that matters...
PLEASE HELP!!
Listen to my music | Visit my garage
Old July 11th, 2007, 07:08 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
what year?
Old July 11th, 2007, 07:12 PM   #3
fogged306's Avatar
89 GT
you need pioneer removal keys... either look on ebay or check a local stereo shop. If you take the trim ring off there is slots on either side of the radio between the unit and the cage. this is where you insert the keys. If you are desperate, two thin pieces of metal at least 4" long will work but it might be a pain in the ass.
If you go to the stereo shop, see if they will pop it for you. If they are a cool place they might even do it for free.
Old July 11th, 2007, 07:14 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
or you can use a slotted screwdriver to pop the pins.
I broke my pins a long time ago.
the bolts hold it in just fine.. the pins are there so ppl can't steal your radio
Old July 11th, 2007, 07:31 PM   #5
fogged306's Avatar
89 GT
if you try that, make sure you have a super thin shaft on the screwdriver. most screwdrivers get too fat for that to work but possibly a jewelers screwdriver or something similar.
Old July 11th, 2007, 07:31 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ what he said is correct
HMUSN approved post right there
Old July 11th, 2007, 08:04 PM   #7
Murderjetz's Avatar
oh. yeah i heard the screwdriver thing but they're pretty thick...they have to go in pretty deep?
Old July 11th, 2007, 08:06 PM   #8
Murderjetz's Avatar
and how do i "pop" the pins? do i push inward, outward...?
Old July 11th, 2007, 08:08 PM   #9
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
outward and about 4 inches
Old July 11th, 2007, 08:49 PM   #10
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
you just unzip your pants and let it find its own way out.. oh wait, didn't realize you said "deck".
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old July 11th, 2007, 09:04 PM   #11
fogged306's Avatar
89 GT
if you get something to get that far, they are designed to push themselves in. you basically just need to get whatever you are using deep enough... I just thought of something that would probably do the trick... butter knives!
Old July 11th, 2007, 09:05 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
stop postwhoring tech threads
Old July 11th, 2007, 09:20 PM   #13
Murderjetz's Avatar
they'd be too wide. at least mine would...the slots arent very wide at all.
I think I'm just gona have to go buy some pioneer removal keys...I can't find anything that would do the trick.
Thanks for the help though.
Old July 11th, 2007, 09:23 PM   #14
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
sorry man, couldn't resist.. when i saw the perfect opportunity to make a joke i took it.. wont happen again :wink
MM 1 am boner crew
Old July 11th, 2007, 09:25 PM   #15
fogged306's Avatar
89 GT
You can actually do one side at a time... it will give you a little more room to play with, so you may be able to get the knife in there. Its tricky, but possible. just leave the face on so you have something to grab onto and when you get one side out, just don't let it click back into place. you can also use a hook pick in the cd slot with the face off, just dont pull too hard with that or you will break the plastic really easily.
Threads Similar to: How do I pull out my deck??
Can't Get My Scanner To Pull Codes? 81 Merc. Capri 5.0 Mustangs 10 December 12th, 2009 04:19 PM
Pull Timing? AnglicoGT98 96-98 1 September 5th, 2007 01:47 PM
Went To Pick n Pull Today... 99mustang232 Southeast 20 July 19th, 2007 11:41 PM
Where is it best to pull the 3.8 out from? 2000Silverbullet V6 Mustangs 9 May 25th, 2007 07:32 PM
Any quick mods I can pull on an 06? WuTimeUT 2005 - 2010 6 January 20th, 2006 10:08 PM
