Alpine Type R Subs, Need Help on Needed Amp(s)
Old July 21st, 2007, 04:59 PM   #1
crossfire876's Avatar
1998 Dodge Dakota Sport
crossfire876 is on a distinguished road
Send a message via AIM to crossfire876
I just picked up 2 ALPINE TYPE R SWR-1222D 12" 3000w CAR SUBS. Now I need to buy amp(s) to power them. I have no idea what to get. Thanks for the help.
2003 Mustang GT-SOLD-1996 SVT Cobra -SOLD-
Old July 21st, 2007, 08:07 PM   #2
Moderator
Look for a mono amp. I power my Alpine Type X 10" subs with a Clarion 1500 watt unit. Here: Clicky
Stick with a well known name brand, and purchase as much wattage as you can afford.
Old July 21st, 2007, 09:46 PM   #3
Murderjetz's Avatar
Murderjetz is on a distinguished road
Send a message via AIM to Murderjetz Send a message via MSN to Murderjetz
I'm definitely not a pro on the subject, but wouldn't he need a 2-channel amp since he has 2 subs?
Listen to my music | Visit my garage
Old July 22nd, 2007, 08:43 AM   #4
Moderator
Nope. Mono amps can power multiple subs. You can power more than one speaker with one pair of speaker outputs. It's how you wire the speakers, either in series, or parallel, that determines the load, measured in ohms, on the amplifier. The lower you can get the ohm number, the higher the load on the amp, and the more it will output. You just have to ensure that you don't go below that amplifiers rated ohm stability number.
Not sure how to wire in series or parallel, or how to do the math to arrive at a given ohm number? Learn how here: OHMYLAWDY!
Old July 22nd, 2007, 11:40 AM   #5
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
mono amp + a nice thick RCA cable that can withstand that much power =T cause if you got a good amp and good subs with a garbage rca cable it wont be able to use it at its peak . also make sure you get dynamat or itll sound dirty...
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old July 22nd, 2007, 11:56 AM   #6
Moderator
Yeah don't cheap out on wire. That's akin to building a powerful engine, and using a shitty fuel system for it.
Old July 22nd, 2007, 12:00 PM   #7
fogged306's Avatar
89 GT
Thats a common misconception. The RCA has nothing to do with power handling. at best it will need to carry 8v and thats if you have an excellent headunit. I've actually used the $2 bulk RCA's we get on high wattage subwoofer systems and noticed no loss in power or clarity over a set of good RCA's. It wont matter much if you run cheap RCA's on sub amps, it will, however, make a difference when you run a highs amp (interior speakers) with cheap RCA's as opposed to good ones.
Lemme see if I can explain this wiring for you... as you guys know, I suck as breaking stuff down, so here goes. When you wire paralell, you attach all the positives together and all the negatives together and basically pretind like you have one speaker. to find the ohms, you divide the number of ohms of the speaker by the number of speakers. for example, if you have two 8ohm speakers and you wire in paralell, you divide 8(number of ohms) by 2(number of speakers) and get 4. the end result would be a 4ohm load. When you wire in series, you add them together. if you hade the same two 8ohm speakers and you wired them in series, you would add the two together 8+8 and get a total ohm load of 16. when you wire in series, you take the positive of one speaker and attach it to the negative of the next, basically daisy chaining the speakers together. So in the end you would end up with the positive from one speaker going into the amp and the negative from the other speaker going into the amp.... if that makes no sense, that is the exact reason that I will never become a teacher.
Old July 22nd, 2007, 12:04 PM   #8
fogged306's Avatar
89 GT
Also, when looking for and amp, you want to match the RMS numbers form the speakers to the amp, don't try to match the peak numbers. And like zippie said, dont go cheap on the amp.. a lot of cheaper companies will over rate their amps and saw its pushing 1000w when in reality its only pushing 400w. Try to find amps with the CEA rating on them, all the good companies will have this, Alpine, Kicker, MMATS, JL, Rockford, and so on.
Threads Similar to: Alpine Type R Subs, Need Help on Needed Amp(s)
SUBS? theyanks904 Audio/Video 11 July 16th, 2007 04:52 AM
Alpine Audio Setup MustangMo Audio/Video 61 May 24th, 2007 03:28 AM
Anyone have a Subs? Youngin Audio/Video 27 March 29th, 2007 01:14 AM
alpine-w200 but retaining the use of shaker1000 amp/subs bostonbands 2005 - 2010 0 January 6th, 2007 09:36 PM
