New Stereo
Old August 4th, 2007, 10:05 PM   #1
Shorty's Stang is on a distinguished road
New Stereo
I have the mach system in my 2002 mustang, and the bass is not very good. So i bought 2 10" MTX subs and I am trying to find out if i can wire an amp from my stock stereo. I heard about an LOC converter does it work?
Old August 4th, 2007, 10:13 PM   #2
Moderator
The converters do work yes. Another option is for you to purchase a mono amp for the subs that is capable of accepting a high-level input connection. That's a facny way of saying you can use the regular speaker wires from the wire channel of your head unit to power the amplifier, and thus use your fader as a sub control.
Old August 4th, 2007, 10:14 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
h0m0$n4m3Ð21p$4¥wh47?.
Old August 4th, 2007, 10:15 PM   #4
Moderator
Cheese¿
Old August 4th, 2007, 10:16 PM   #5
Moderator
EDIT:
The converters do work yes. Another option is for you to purchase a mono amp for the subs that is capable of accepting a high-level input connection. That's a fancy way of saying you can use the regular speaker wires from the rear channel of your head unit to power the amplifier, and thus use your fader as a sub control.
Old August 5th, 2007, 01:11 AM   #6
Amps
So once i buy a LOC convertor, and I connect the amp to it, the amp should work even with the mach system. Once I buy a new amp, I also should take out the 2 small factory amps that are already mounted on the roof of the trunk, correct?
Old August 5th, 2007, 01:50 AM   #7
Moderator
Yes that is correct. Ideally, you will also eventually purchase an after market head unit that has separate sub level preouts (rca's), and at least one other set of preouts for a nice 4-channel amplifier. If you can afford it, also get as many volts on the preout side as you can, as amplifiers run on volts the way your engine runs on gas/air. The more volts in, the more potential for power there. You just also have to keep in mind that the amplifier should be able to handle whatever voltage you put in to the input side.
Threads Similar to: New Stereo
Need Stereo Options/Help.... MaverickMLFD371 All Other Vehicles 0 November 13th, 2007 03:24 PM
Stereo in my 83 GT jake1191 5.0 Mustangs 3 July 6th, 2007 11:57 AM
Stereo HelP! BlackStallion00 Audio/Video 1 June 16th, 2007 10:59 AM
New Stereo? Shorty's Stang V6 Mustangs 70 May 14th, 2007 03:03 PM
Stereo Poping Help Dawgs2099 Audio/Video 5 April 23rd, 2007 08:13 PM
