HID help, kinda asap
Old September 14th, 2007, 12:25 AM   #1
energiesource's Avatar
energiesource is on a distinguished road
So I bought an hid kit a long time ago, it was some asian company, so the passenger side started to flicker about a month after i got it, and then it eventually would either a) not turn on or b) turn on and off, until it just stopped working, checked the connections and the power stopped at the ballast so im guessing it was a blown ballast, anyways, i bought a new one from american muscle and its doing the exact same thing except on the drivers side now, i emailed them and all they told me were to check the connections, which i did several times over. anyone have this problem?
Old September 14th, 2007, 12:51 AM   #2
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
check the headlight switch. they like to go bad once n awhile espically when you do something with the headlights. also you might want to check your connections
Modifications and pics in my Garage...
Reps Appreciated!
Old September 14th, 2007, 01:01 AM   #3
like...the switch in the dash? wouldnt they both go out if that were the case, as well as the connections seeing as how they both run off one plug
Old September 14th, 2007, 01:23 AM   #4
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
yes the switch on the dash... not necessarily. if the switch is going bad they act up like what you are describing. just something to check into ya know.
Reps Appreciated!
Old September 14th, 2007, 01:25 AM   #5
oh it does it when i take my ebrake off for the DRL's too.
Old September 14th, 2007, 01:27 AM   #6
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
it sounds like you have a wire connected to a wire that it shouldnt be connected to. that or a wire is shorting out some how. like a bare wire touching the frame or somthing.
Reps Appreciated!
Old September 14th, 2007, 07:25 PM   #7
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
my friends had that happen twice now on his 06 tiburon but were not sure why. he bought a similar kit to the 3 i've purchased and none of the sets i own have been any problem. i dunno if he just got unlucky with his set or theres somethin about his car thats messin em up. Like his will always flicker when you turn em on if the cars not running. mine on the honda and both sets on the mustang dont do that, whether the car is off or on it doesnt matter so honestly i'm not sure. sounds like your ballasts may of went bad. see if the seller you got them from has a warranty and get it replaced. also did your ballast/ignitors have any kind of second relay of some sort or did it require extra wiring to hook them up. all the sets ive ever used are just direct plug and play and no relays, yet to have a problem with them.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Threads Similar to: HID help, kinda asap
WHAT KINDA HEADS SHOULD I BUY BROKINARROW 5.0 Mustangs 31 October 18th, 2007 02:42 PM
kinda sad news.. droppedbass87 96-98 8 August 10th, 2007 05:56 AM
kinda gay WilltheThrill Videos 17 July 22nd, 2007 09:57 AM
kinda upsetting ATLmustang 99-04 14 February 3rd, 2007 05:13 PM
Kinda new here itschristorres8 New Members Introductions 8 October 22nd, 2006 02:57 AM
