PROBLEM...NEED HELP ASAP
Old October 3rd, 2007, 01:18 PM   #1
VSR13 is on a distinguished road
Send a message via AIM to VSR13
well i'm taking a few pieces out of the stang to get ready to trade it in...i was cutting a wire from the glow gauges i had installed and when i cut one of the wires my radio, windsheild wiper control and spray, and my dome light quit working...everything else is fine. i'm guessing it's a blown fuse. where should i start looking...it's supposed to rain this weekend so i need to fix this asap.
please help guys
Old October 3rd, 2007, 01:21 PM   #2
TheUNZippee!'s Avatar
Are you positive you haven't accidentally cut another wire, or squished a power wire for one of those things up against a ground wire, and shorted something out, or as you said, blown a fuse?
To test the fuses, find your fuse (check your owners manual for locations and fuse numbers), and check the fuse visually. Also, just because the fuse may look good physically, does not mean it may not be bad. In that case check the fuse for continuity using a meter.
Originally Posted by My Wife
Old October 3rd, 2007, 01:30 PM   #3
which fuses should i start wit thought? the ones under the hood or the ones under the dash...i'm gonna go pick up a volt meter today.
i know i didn't cut the wrong wire bc it's diff color wire from the others around there...i was stupid and forgot to turn off the car b4 i went cutting
Old October 3rd, 2007, 01:31 PM   #4
Start with the ones under the dash
Old October 3rd, 2007, 01:36 PM   #5
ok i'l have to check it when i get home...when i use the volt meter. wat setting shoudl i use?
Old October 3rd, 2007, 01:41 PM   #6
Check this link out, it explains it better than I can: Clicky
Old October 3rd, 2007, 01:43 PM   #7
Another easy way is to check the fuse for voltage while the fuse is still in the holder in the fuse panel. Just set the meter to check for voltage, and then check each side of the fuse. If there is no voltage at one side of the fuse, the fuse is bad.
Old October 3rd, 2007, 01:44 PM   #8
ok cool thanks man i hope i'm able to find it soon
Old October 3rd, 2007, 01:45 PM   #9
and the voltage would go by wat the fuse says on the top?
Old October 3rd, 2007, 01:48 PM   #10
Set your meter to check for volts. The car is 12 volts, so you should get roughly 12 volts on the meter when you check each end of the fuse, while the fuse is in the holder. Just stick the pointy probe in each end of the fuse one side at a time and read the mter. It should say 12 volts at both sides.
Old October 3rd, 2007, 01:48 PM   #11
Ahh I see what you're saying. No, that number on the fuse is the fuses amperage rating, or how many amps it will take before it blows, thus preventing an overloaded circuit.
Old October 3rd, 2007, 01:49 PM   #12
ok sounds good man...i'll let you know how it goes...hopefully i can find it
Old October 3rd, 2007, 01:50 PM   #13
All righty man, best of luck fixing her up
Old October 4th, 2007, 10:25 AM   #14
FOUND IT!! well i found a blown one i just need to go buy a new fuse...i hope it fixes the problem
Old October 4th, 2007, 01:21 PM   #15
it works!!! my car's alive again
Threads Similar to: PROBLEM...NEED HELP ASAP
NEED HELP ASAP!! 92stang0802 2.3 Mustangs 5 October 30th, 2007 10:04 PM
NEED HELP ASAP!!! Basics V6 Mustangs 19 October 18th, 2007 10:33 PM
headlight problem, need help asap! madden Audio/Video 3 May 28th, 2007 11:39 AM
Girl friend problem, need advice ASAP Tony_90fox The Clubhouse 42 April 27th, 2007 02:03 PM
Big Problem Need Help asaP New88MustangOwner 5.0 Mustangs 1 December 30th, 2006 03:58 PM
