firewall
I need to run the power wire from my amp to my battery...any suggestions?
Find an existing rubber grommet in the firewall. Poke a hole through it, ensuring you don't damage any other wires/plumbing.
Stick a coat hanger or fish through the hole. Tape your power wire to the coat hanger. Pull the wire through the rubber grommet. Be careful when punching the hole through the grommet that you don't pop it out of the firewall, as they can be a bitch to get back in. |
any idea where the best and easiest one is?
will i be able to fit a 10 gauge wire through it?
Sorry, I'm not familiar with the 96 cars. But you should be able to find a grommet that will fit 10 gauge through it. Sometimes the grommet is a bitch to get to, but it's the safest way to run the wire.
Check around your steering column, or if your experienced just drill a hole and put in a grommet, if your not your local stereo shop will prolly do it for you cheap.
"Tame 'Til Off The Chain" 67 Coupe - Restore in progress |
Threads Similar to: firewall
| Firewall Hole? | mixedbreed02gt | Audio/Video | 3 | October 28th, 2007 12:33 AM |
| Firewall Cooling line???? | Mat2894 | 99-04 | 7 | September 29th, 2007 12:35 AM |
| Firewall adjuster | Drick | 5.0 Mustangs | 20 | September 26th, 2007 11:29 PM |
| firewall tag | Iownastang | 5.0 Mustangs | 9 | September 12th, 2007 08:50 AM |
| Firewall | Invictus | Audio/Video | 6 | November 27th, 2006 05:50 AM |
