HEADLIGHT SWITCH
Posted earlier about my headlights flashing on and off all the time and yall said it might be lose wires or a fuse but i started messing with the switch to turn them off and on and everytime i would touch it the lights would flash when i touched it,im pretty sure this is the problem.So do any of you know how to change the switch out??Thanks!!
remove ur headlight knob.remover the 2 screws holding the dash on.remover the 2 screws holding the headlight switch in,pull out an there should be 2 snap thingys on the side of the switch pull apart an side the switch out,install new one.put everything back together.atleast thats how my 00 gt is hope this helps you,good luck
Threads Similar to: HEADLIGHT SWITCH
| headlight switch... | Mountainguy | Audio/Video | 1 | September 19th, 2007 05:09 PM |
| 94-98 headlight help | Nick_Rapitis | V6 Mustangs | 12 | August 13th, 2007 08:29 PM |
| Headlight switch knob | warrior86 | V6 Mustangs | 8 | May 24th, 2007 01:57 PM |
| one headlight | Dj1123 | Visual | 13 | May 16th, 2007 07:02 AM |
| 06 headlight!!! | Ware | Visual | 1 | May 12th, 2007 07:16 AM |
