Access the rear of stock radio
Old August 14th, 2006, 03:40 PM   #1
achief15's Avatar
achief15 is on a distinguished road
I purchased an add on adapter for my XM roady 2. I'm fairly sure I can take care of the install IF one of you more knowledgable folks can tell me how to access the rear of the unit. 06 GT, factory 6 disc and Shaker 1000. Also, there is an "AUX." button on the face plate of the radio. Is there any RCA or other ports on the back for items such as the XM, iPod, MP3, etc.? Thank you for any advice or help.
Glenn
Outer Banks, NC
Old August 15th, 2006, 07:32 AM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
If it was a 66 I could help.
Classic Mustangs are the best! Get one.
Old August 17th, 2006, 02:10 PM   #3
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
There has got to be either RCA plugs or an interface on the back of the stereo if there is an "AUX" button on the front.Most likely you'll find it is an interface and you'll have to buy a interface adaptor that converts to RCA cables.I'll post a link after this post.Is there any "headphone"looking ports on the front of your head unit?
Hers the link that has the adaptor you need
http://www.myradiostore.us/auxadapte...aux-input.html
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Old August 17th, 2006, 06:20 PM   #4
achief15's Avatar
Thank you. Any idea hot to get to the back of the thing? Or remove it?
Glenn
Old August 17th, 2006, 06:48 PM   #5
B0mb3r645 is on a distinguished road
Send a message via ICQ to B0mb3r645 Send a message via AIM to B0mb3r645 Send a message via MSN to B0mb3r645
Does it have small holes in both sides (2 on each, about maybe an inch and a half or so apart?)
If so, you'll need a set of Ford Radio Removal Tools. You can probably find them at Wal-Mart or a place who usually sell wire harnesses or dash kits. Here's a pic to get an idea.
"Look up!"
Old August 18th, 2006, 12:11 AM   #6
nope, requires minor dash disassembly to get to. I'll try to post the r&r info from the shop manual tomorrow.
88 Mustang Coupe
www.rickscarcare.net
Old August 18th, 2006, 01:10 AM   #7
320hpPony?'s Avatar
Most all ford factory or upgraded head units use those "U" hooks.You can use coat hangers if'n you bend them right!! You would have to gently pry the unit out with the coat hanger pushed full into all 4 holes at the same time.Worse case scenario, you'll prolly haffa pull the trim piece that surrounds the unit then unbolt 4 hex head bolts.Once you get the 4 bolts out you'll have this pain in the ass plastic piece that is bolted to the back of the unit that you damn near gotta break to get it out. But yeah send some pics of the unit and one with the trim around it pulled off if you can and i'll tell ya zactly howta get the bugger out bro.
Old August 18th, 2006, 12:25 PM   #8
achief15's Avatar
Twist.
Thanks for any tech advice you can find and forward. The Ford dealer here is an ass if you don't buy from him, and I got mine at Sadler's back home. I wish it did have the old style 4 hole removal though, they were easy.
Glenn
Threads Similar to: Access the rear of stock radio
stock radio nealkb Audio/Video 0 September 26th, 2007 03:25 PM
stock radio gooberhead320 V6 Mustangs 9 July 9th, 2007 11:48 AM
how do i take the stock radio out of my cobra? 94pacecarSVT 94-95 3 June 21st, 2007 01:37 PM
take out stock radio? Jucostud 2005 - 2010 9 February 9th, 2007 08:52 PM
