a couple random questions
Old August 21st, 2006, 11:09 AM   #1
mrbetz is on a distinguished road
okwell as lame as it sounds....if anyone has a 94-98 mustang (v6 if it matters) and cud just get me the measurement on how tall the trunk is that would be awesome cause im trrying to build my sub box and dont want to oversize it (my car isnt wit h me yet) and a bit off the mustang topic....any reason you can thi9n of that woud make my subwoofer pump the wrogn way...like inwards thasnks
Old August 21st, 2006, 05:19 PM   #2
B0mb3r645 is on a distinguished road
Send a message via ICQ to B0mb3r645 Send a message via AIM to B0mb3r645 Send a message via MSN to B0mb3r645
Guess I'm out. I have a 97 BUT vert trunks are smaller My sub box has to face the front at all times because the back of it won't fit inside the trunk, but will fit at the door when it is closed.
I just have one of the Wal-Mart 12" boxes, lol.
"Look up!"
Old August 22nd, 2006, 12:39 PM   #3
Jinxed is on a distinguished road
you have it wired backwards if it is recoiling inward. Switch your positive and negative wires around on the back of the sub, or on the connection plate on the box.
"Tame 'Til Off The Chain"
67 Coupe - Restore in progress
Old August 23rd, 2006, 01:17 AM   #4
Lol my connection plate is FUBAR, the connectors broke a long time ago and I just wired straight to the sub. Might not be smart, but its better than spending money.
"Look up!"
Old August 23rd, 2006, 12:34 PM   #5
lol thats what ill be doing...its not a problem lol ...but even when i switch them it doenst make a difference
Old August 23rd, 2006, 03:07 PM   #6
do you have two subs in the box? are they wired seperate or is there one terminal on the box? If there is one terminal and you this problem you need to pull out on of the subs and make sure it is wired correctly. This could get complicated depending on your ohm load and what subs they are, and how they are supposed to be wired, (serial or parrell/loop) But I would still pull out the one firing backward and check it's connections
Old August 23rd, 2006, 05:42 PM   #7
actually its only the single sub coming from a bridged connection
Old August 25th, 2006, 01:45 PM   #8
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
It will ALWAYS LOOK like it is pulling inwards no matter what way the wires are connected.You cant physically "see" the difference the connections make only hear how it blends into the system.
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Threads Similar to: a couple random questions
Couple Random Pics TheUNZippee! Pictures 13 November 9th, 2007 11:09 PM
Couple Questions Youngin V6 Mustangs 12 October 8th, 2007 08:49 PM
A couple of questions unhungzero Visual 8 September 10th, 2007 07:48 PM
i have a couple questions rx1_ns 96-98 25 July 10th, 2007 05:25 PM
