Fuel Pump Cut Off Switch For Security
I'm still pursuing an off the beaten path source of security. I had originally planned to put in a pump cut off switch somewhere in the cabin. My gf's Murano has a cool system in which you don't need a key, you just need the little proximity key fob nearby to start the car (in your pocket, back pack, etc..). Does anyone know if there is a simple switch that also works like this. Something I can mount in the accesory port in clear view.
no effing clue... although if you had a 94-04 I could tell you how to hook up said switch. but I do know I have seen something like that on that how stuff works site
2005 Torrid Red GTO m6
well
Theres already a switch in the trunk
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
Proud American
there is also a switch on my 96 under the steering wheel that cuts off fuel as well.
MM's Resident Ricer
2006 Scion tC
13.001@113
Just get a cheap battery kill switch from jegs with a removable key. No battery power = no car getting stolen
that can easily be hotwired.
1988 Mustang Notch
it's a bad bitch..i promise
So, i would rather have my fuel cut off than a battery cut off...
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
MM's Resident Ricer
2006 Scion tC
13.001@113
It can't easily be hot wired. It cuts the circuit to the battery, they would have to pop your hood trace back the wires disconnect it, re connect it, then get back in your car and hot wire the car itself. There is no way any car thief is that stupid or going to take the time when they could just grab the honda parked beside you.
lets see
pos honda or hotwire a mustang a nice engine in it?? think about it
MM's Resident Ricer
2006 Scion tC
13.001@113
a car thief isn't going to take the time to to work on the mustang if he hot wired it and got nothing he would go to the next car. It isn't like he is going to keep it he would just run to a chop shop and grab what cash he could for it. A battery kill switch is the easiest and best way to keep your car from getting stolen since it is only like 15 bucks for the switch and you can install it in 30 mins.
Thanks for all the responses. Sorry I'm so late but I've been in Indonesia for the last 10 days.
i seen a kit in a hot rod mag once... the system was kinda like a six pin trailer setup
cant really describe it but you hook this up inline your hot going to three things like fuel, ignition, starter. then your key crosses the terminals and allows to be started
FX4 Crew
Crew member #3 |
Someone tried to use a screwdriver on my suv
Threads Similar to: Fuel Pump Cut Off Switch For Security
| fueld pump cutoff as security | catchtheroadrunner | 2005 - 2010 | 0 | September 26th, 2007 03:46 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| Fuel Shut Off Switch | jangrif | 2.3 Mustangs | 5 | February 28th, 2007 06:57 PM |
| Info on Switch Fuel Injected to Carb. | 86blkmustang | 5.0 Mustangs | 2 | February 5th, 2007 11:27 AM |
| Fuel Pressure Switch | fordpat | Classic Mustangs | 3 | November 15th, 2006 05:57 PM |
