Installing Interior Neons
Old September 3rd, 2006, 11:55 PM   #1
Aeroz is on a distinguished road
First.. I havn't seen any topics on something like this.. so I figured id make one. And if anyone has experience with putting interior neons on a mustang I would love to talk to them so I can figure this out easier..
Anyhow, I really dont like the whole Cigarette Lighter adapter.. just looks tacky... I have heard of other ways of doing it, like putting them straight to your battery.. But im not exactly sure how to set that up.. and for each neon, that would be ALOT of wires to put straight to your battery... Any help?
Old September 4th, 2006, 12:00 AM   #2
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Feel free to PM me about this as( I am gonna catch hell for this) I guess I am the residential neon guy. It is very easy and can be done with minimal headache.
Old September 4th, 2006, 01:42 AM   #3
B0mb3r645 is on a distinguished road
Send a message via ICQ to B0mb3r645 Send a message via AIM to B0mb3r645 Send a message via MSN to B0mb3r645
For each Neon... Just hook them into a switch. Just splice them to 2-1, 2-1, 2-1, 2-1 until you have 1 going to the switch, then the power side of the switch to the battery and the ground to a ground. Worked good for me with my fog lights and my window fluid sprayer lights on my Honda, and works still after 2 years. But on the line to the battery, I would put a fuse on there just in-case something happens, don't want to burn out those neons.
Either that or I know there are wire consoles out there you can hook the wires into, and then a power wire you could do the same above with.
"Look up!"
Old September 6th, 2006, 04:30 AM   #4
jealousy is on a distinguished road
first of all l.e.ds are the way to go, brighter longer lasting, wont break, 2nd, i wired mine through the firewall and into the fuseox under the hood, but the easiest way is to just stick the wires under a fuse thats always hot under your dash, if this doesnt make sence pm me
Old September 10th, 2006, 09:18 PM   #5
cboog25 is on a distinguished road
Send a message via AIM to cboog25
you could do that or just run it to your battery.. the only difference is that if you hook it up to your battery they will work even if your car is off but if you have them hooked to a fuse they will only work when it is on
Chris
Old September 11th, 2006, 01:15 AM   #6
Personally, I would just do it from the switch, not hard to mount a switch and find a nearby ground, but you could just do the fuse idea, since its interior anyways.
"Look up!"
Old July 5th, 2007, 05:43 PM   #7
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
actually ... You could always hook it up to the fog light switch so whenever you have your fog lights on at night you have your neons as well.
Old July 5th, 2007, 06:07 PM   #8
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
you can pm me too if ya need help, i've put leds and neon all thru my car....including engine bay, grille, underglow, vents, foot wells, inside my sub box, behind my rear delete, in trunk compartments...just let me kno if ya need any help....
ps i also recommend leds bc of the above reason jealousy said
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old July 9th, 2007, 03:38 AM   #9
3.9L V6
I just got lucky and got a full LED kit w/ inside LED's too for $40. I've gotta say, next to neon it just looks more vibrant. The local advance has the same kit for $170, w/o the inside lights. They were $20 extra, but its well worth it. I'll post a pic hopefully soon to show you.
P.S. Some kits come w/ a box that all the lights rund into, w/ one positive, and negative wire to run to your battery.
Threads Similar to: Installing Interior Neons
Post Pics of your neons Kenzo Pictures 2 August 18th, 2007 10:05 PM
Neons Murderjetz Visual 47 April 23rd, 2007 10:19 PM
underbody neons.... RIDIN5.0 Audio/Video 2 February 23rd, 2007 05:41 AM
Neons? B0mb3r645 Visual 36 August 20th, 2006 06:46 PM
