How to install aftermarket headunit
Old January 21st, 2008, 09:52 PM   #1
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
alot of people, dont know how to do. I did this a few weeks ago and though id cast my pearls of wisdom
theres gonna be soldering. you need heat shrink some solder and a soldering gun. the wiring harness only has wires so you need to splice the wires together. Most wiring harnesses come with diagrams so thatll be the most helpful thing.
1. take off your dash. to do this,take the shifter plastic off. It is on top of the part you need ot take off. take a flat tip screw driver and put it in the crack where your dash meet the shifter bowl I guess youd call it. pop it up and just let it sit there.
2 take off the dash. to do so, do the same as you did with the shifter, but on the dash. I found it easier to work from the a/c vents down.
3. take the dash off and at the bottom there will the defroster, trac on/off, and fog light switches. pop the connectors out, not the buttons (pain in the ass with big fingers) and just put the dash in your back seat.
4. get a nut driver, 1/4'' I think it was and unscrew the stock headunit. when you pull it out theres going to be wires connecting it to the car. Pop these out. a few are a little pain in the ass.
5. go back inside your house and get the wiring harness. now find a diagram of your system on the internet. make sure all the wires match up. if i remember right wires 3 and 7 are ground. just look it up.
6. now the soldering. take your wiring harness and the headunit connector. most of the time theyll all be color coded and good to go. but open your manual for the headunit and do it by the book. match every wire up that needs to be.
7. to solder the wires together, you take a wire stripper and strip the wire cover off to expose about 1/2 of wire.put a heat shrink tube about 1in long on every wire. now take the matching wires and form them into an X. now fold them voer each other until you get it as flat as possible. now take your solder and soldering gun. take some solder and put it on the gun. put that UNDER the wires to create a bridge. it transfers the heat to melt the rest. now take the solder and go across the top of the wires. try not to get the wire covers as this will melt it. after you get the solder on there itsnow time for the heat shrink
8. pull the heat shrink up and put it over the joined wires. take a lighter and go lightly across the tubing. make sure it shrinks tightly and try not to burn it. it doesnt hurt it if you d, but try to avoid at all costs.
9. after you get every wire spliced, its time to hook this SOAB up. take the headunit,the headunit casing, and the wiring harness out to the car. hook everything up. make sure everything fits well. if it doesnt fit, DONT FORCE IT. work with it and move it around. once you get the headunit in and all is good, make sure the casing is centered and in a good spot.
10. put the dash back on and then snap the shifter bowl back into place. make sure everyhting looks good and your good to go.
get that thing jammin man
Mods in garage. Built suspension and gears since posted times.
Old February 2nd, 2008, 02:20 AM   #2
mixedbreed02gt is on a distinguished road
Send a message via AIM to mixedbreed02gt Send a message via MSN to mixedbreed02gt Send a message via Yahoo to mixedbreed02gt
actually the bolts that remove the radio are 9/32".
and also I already did a write up on this.
http://www.moddedmustangs.com/forums...ustang-gt.html
[URL="http://www.cardomain.com/ride/2522054/1"][SIGPIC][/SIGPIC][/URL]
[URL="http://www.cardomain.com/ride/2522054"]
My Car Domain Website[/URL]
Entertaining Offers For My 2002 Mustang GT
[URL]http://www.moddedmustangs.com/forums/sale/57736-entertaining-offers-my-2002-mustang-gt.html[/URL]
Threads Similar to: How to install aftermarket headunit
How To Install An Aftermarket Tach TurboLX Electrical & Wiring 4 March 8th, 2012 11:53 PM
How To install an Aftermarket Tach in a 96-98 MustangMatt96GT 96-98 30 May 5th, 2008 09:22 AM
Aftermarket Oil/Water Gauge Install GTPONY1 2005 - 2010 4 January 19th, 2008 03:33 PM
My new headunit... ChrisJ The Clubhouse 83 January 15th, 2007 05:40 AM
How do you install new seats that are aftermarket Sithlord V6 Mustangs 0 June 26th, 2006 09:56 AM
