Wax on, Wax off
Automatic windows & brakes causing diming lights
When I press up or down on my window's button my lights all around dim, and I can hear my engine lose some RPM's. This also happens when I touch my brakes. I can hear feedback in my subs when I hit the brakes as well.
I have replaced the battery with a Optima Yellow top that is about a year old. I have a 4guage ground from the battery to the chassi of the car... any ideas where I should start looking? Mabey check all grounds... howerver I am fairly certin they are all good and tight. The sub's ground is tight as well... any ideas?
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
03 gt, 95 740i, 96 disco
![]() ![]() iTrader: 2 reviews
your alternators not supplying enough power.
^what he said. Sounds like your alternator is on its last legs.
2004 Mustang V6
![]() iTrader: 1 reviews
Get alternator checked, if no problem then just add a battery capacitor to your car
Wax on, Wax off
ahh crap... alright I will run by the parts store and have them check it... I had a prob with the alternator not having a good connection awhile back.
I lost the nut that goes on the bolt that holds the connector. So I got one that fit tight and put it on there.... oh well taxes are coming soon, might have to get a new one. Thanks for the replys
Wax on, Wax off
Well, Autozone tested my alt and it was pumping out 13.8v at idle....
There was only about .5v drain when I hit the window motors. Im going to check the fuse to the motors tomorrow and check all my grounds in the engine compartment. Any other ideas I can try?
Wax on, Wax off
any ideas?
Tree Fiddy Z
do you have a capacitor for your subs and amp? If you're running a decent sound system...this is a must have. This will keep your lights from flickering by providing constant voltage to your subs and amp. It will also save your alternator.
Wax on, Wax off
Eh, I dont like Caps... used them and they dont do that great. All they really do is use power from you car to charge another small battery in the cap. Which gets drained by using the subs, and just has to be recharged. Its basicly adding a small battery. The best way I found to elminate the dimming from subs:
Big 3 upgrade 4 guage from Alt to Battery, with atleast 100amp inline fuse extra 4 guage ground from bat to chass 4 guage ground from alt to chass This got rid of my dimming and drainging problems from my subs. The question is how my windows are casing this... I do NOT want this to run into a Capacitor debate. I apperciate you tryin to help, just dont like usin caps personally.
2004 Mustang V6
turn your subs and radio off. If you then hit your brakes or windows do they dim?
Wax on, Wax off
at work, but will check when I get off...
2005 Torrid Red GTO m6
Haha
thats so funny last month or so i poted a vid where my car did the same thing and your running a sub and amp?
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
What you need to do is check the amps that the motor uses to pull the window down and up and from there do the math to check if anything is outta wack, a .5V drop for your windows is normal and by the way my car does the same thing. You have to consider that with your lights on it pulls more amps from your battery and with you using the windows at the same time you will see the voltage drop in the dash.
SVTfocus, F250
yeah i would go through and check all your grounds and connections.
it wouldnt hurt to grind down the paint on all the grounds. good call on the big three upgrade btw. |
Threads Similar to: Automatic windows & brakes causing diming lights
| Can i swap my 1985 1/4 rear windows/louvers for 87+ Windows? | noyz25 | 5.0 Mustangs | 2 | September 10th, 2007 12:23 AM |
| Air conditioning causing the car to over heat | Snipe061 | V6 Mustangs | 4 | August 15th, 2007 10:37 PM |
| weather conditions causing over heat or something else?????? | Dennis | 96-98 | 10 | August 6th, 2007 06:13 AM |
| MAF causing CEL ? | Blown5.0 | 5.0 Mustangs | 0 | June 9th, 2007 10:26 PM |
| What might be causing this.... | Vabeachmustang | 2005 - 2010 | 1 | March 31st, 2007 01:34 AM |
