Replacing The 8 Inchers In The 05-07
Old September 16th, 2006, 08:19 PM   #1
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
what would be the best replacement for the new 8's in the new mustang. i know there are some kickers and pioneer's, but wouldn't it be pretty easy to make a spacer to get the additional mounting depth to add better speakers.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old September 26th, 2006, 07:11 PM   #2
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
Are most aftermarket subs too deep for the enclosure? And yeah a spacer plate would be fairly easy to make. If you can run a jig saw pretty good then it wouldn't be that much trouble. cut a hole just big enuff to mount the sub in and the cut the out side just big enuff to fit into the mounting hole for the sub enclosure(usually will be as big as the total outer circumference of the whole subwoofer). One thing to consider is the volume of the enclosuer and find a sub that will perform properly in that volume.
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Old September 26th, 2006, 08:36 PM   #3
psycho bob's Avatar
07 GT
12.86@104
hey thanks for the info. it is pretty simple to make things for me, but i'm not good with the numbers part for the volume. i'll probably just have someone build a fiberglass panel for the door. i would think they could make it the correct volume pretty easily doing a custom job. either way i'll just be happy to have a car to drive again when i get back. thanks fo the help again
Old December 3rd, 2006, 10:03 PM   #4
daviddunn is on a distinguished road
This is what you have to do...forget about puting in 8" subs in the doors. I have an 06 GT convertible and the car rattles enough stock! If you add subs in the doors youre only gonna make it worse...instead I added 8" Memphis component speakers to fill the space from the stock 8" subs in the doors and put an MTX prefab enclosure in the trunk to fulfill the bass. I used a JLAudio 12" W6v2 in the MTX enclosure.
Old December 5th, 2006, 01:04 AM   #5
psycho bob's Avatar
07 GT
12.86@104
not trying to make a set of 8's be it for the bass, just wanted the best mid-bass above the stock ones. to handle the bass i was actually considering the JL box designed for the 05+ that comes with one 13" JL. the one i'm talking about goes where the factory 10's are in the shaker 1000. who would pay $1300 for those is retarded IMO
Threads Similar to: Replacing The 8 Inchers In The 05-07
Replacing Manifold... Need Help! VSR13 V6 Mustangs 19 November 13th, 2007 04:57 PM
Replacing amp, need help mikebert Audio/Video 6 June 17th, 2007 09:12 PM
Replacing headers.. themainman 99-04 6 June 14th, 2007 03:58 PM
replacing mirror mustang_89 V6 Mustangs 1 May 10th, 2007 07:13 PM
Replacing Shifter cobralini 5.0 Mustangs 4 May 17th, 2006 04:31 PM
