Power window problem
This one is simply messing with my head.
I have a 2000 Mustang Convertible. There is a weird issue going on with the driver's window. I am having an issue where the window will sometimes work and sometimes not when I press the switch to go up and down. As far as I can tell, when it is cool out, the window goes up and down just fine. When it gets warm outside however, it will not do anything. I do not hear the motor engage at all when it does not work. In fact, the only thing that I hear is the click of the switch that I press down. I can not begin to guess what is causing this one. Any suggestions would be appreciated. |
2003 Mustang Cobra
Had this problem in my 03 Cobra, it came down to a motor going bad. A quick fix for short time is while window is down thump the inside panel until it goes up. It only works a few times and then it's time to replace the motor. Hope this helps!
Threads Similar to: Power window problem
| Power window! | Serefire | V6 Mustangs | 29 | April 10th, 2008 09:06 PM |
| power window problem | supercharged04 | 99-04 | 5 | March 30th, 2008 06:26 AM |
| Power Window problem..... | lwhitetrash88l | V6 Mustangs | 1 | September 24th, 2007 02:32 PM |
| Power Window Problem | V6er | General Tech | 1 | August 6th, 2007 03:51 PM |
| power window problem (pulling hair out of my head) | zmykk | General Tech | 4 | August 1st, 2007 07:34 AM |
