Resident DJ
'01 Cobra Vert.
Infamous ZERO Trunk Space for Woofer Box
I have questions regarding the infamous "can't fit a damn woofer box in comfortably in the mustangs w/ the mach audio systems". Obviously you could get a custom box made. I prefer to save money and not...I need a ported box that will fit in the trunk of my 96' GT (w/ mach audio) that can house this subwoofer....any suggestions on how to either make my own??? Or what to do...
Here's the link for the woofer specs.... Infinity - Car Audio |
2004 Mustang V6
![]() iTrader: 1 reviews
single woofer or two? Are you handy with a saw and screw gun and have a basic understanding of geometry?
Resident DJ
'01 Cobra Vert.
yeah. I'm going to college for architecture so geometry ain't a problem. I just want a nice porter box ya know???......with no damn hassel of making it and also getting it in and out of the car. And its just one woofer
#4 | |
MM's Database Error
my box that was in my car until recently...it was a tight fit but it worked...and i do have the mach system
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
Resident DJ
'01 Cobra Vert.
any good places to show how to make em'....well at least put the carpet on the boxes correctly??
Silver '07 GT 5spd
Many times we used to pull out the rear seat (upper and lower) adn then unbolt the frame behind the upper and bend it down. This will get you another inch or so in height to get a larger box in the trunk from the inside. You then simply bend the frame back into place and rebolt averything. I believe the frame bolts are 10mm, and there are 3 of them across the top. Memory is a bit fuzzy on this, but I also think you either have to pull up the very front of the rear deck or there is a trip piece to pull up. It's been at least 5 years since I did this (moved on to another line of work) but I did these things for 9 years, and did this same thing many times.
FI FTMFW!!! 445rwhp, 426rwtq If you're in a fair fight, your tactics suck. |
Silver '07 GT 5spd
Sorry. As far as covering it, there are purpose built carpets for just this thing, as well as a felt-like material that closely matches your trunk liner. Either of these can be made to stretch over 5 sides of a speaker box with a little time and muscle. It's important to round your corners and edges so they don't poke through and/or tear the material. Normally I used a router, but you can make do with a portable belt sander. The carpet is attached to the box with 3M spray adhesive, and can be found at Lowes/Home Depot type places in the paint dept., and further held in at the edges with staples. Trim with a razor knife and voila. Total build time with good equipment used to be about 25 minutes, covered and woofer installed. And I did not use silicone.
Threads Similar to: Infamous ZERO Trunk Space for Woofer Box
| The Space | RyanHNT | The Clubhouse | 2 | June 25th, 2007 06:01 PM |
| my space | bigmike83 | The Clubhouse | 5 | May 21st, 2007 10:59 PM |
| The Infamous Stalling Problem | mikethetigerrr | V6 Mustangs | 12 | March 18th, 2007 03:56 PM |
| Help with Sub woofer | Red87DropTop | Audio/Video | 5 | March 13th, 2007 09:15 PM |
| Infamous Head Light Haze... | Hollywood | Visual | 51 | December 26th, 2006 10:17 AM |
