Door Panel Removal
Old November 1st, 2006, 01:34 PM   #1
MNmustang is on a distinguished road
Door Panel Removal
I have a speaker that is rattling in my 2002 and I have tried to remove my passenger side door panel, but am having some problems. Here is what I have done...what step am I missing?
1.) Popped off plastic assembly around window/lock controls
2.) Removed plastic fastener on front, lower part of door panel near the speaker.
3.) Pulled up on door panel to try to remove...no luck.
Are there any other screws that need to be removed? Or more hidden plastic clips anywhere?
Any help is appreciated, the speaker is annoying the heck out of me.
Old November 3rd, 2006, 12:12 AM   #2
jerb43 is on a distinguished road
yes, you have to remove your inside door handle, and there should be 2 screws behind them! thats how it is on my 98 anyway
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust!
Old November 3rd, 2006, 04:50 PM   #3
Yeah, I looked at that...how do I get the door handle off?
Please excuse the ignorance. I really appreciate the help. This speaker is driving me nuts and I love the car too much not to drive it because of it.
Old November 3rd, 2006, 04:56 PM   #4
well, if it is like my 98, the plastic covering should just pop off, the your window buttons, should pop off as well, slide those to things out of the way, and the screws should be exposed, they are little phillips heads, i think 3 or so.... hope that helps!
Old November 11th, 2006, 09:32 PM   #5
King Mustang is on a distinguished road
you dont have to pop your handle off. just take the 2 black screws out and grab each side of the pannel and lift up. it should come off prety easy.
Old November 12th, 2006, 03:13 PM   #6
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
yeah the two screws behind the handle insert and the door pin. then just lift up and it should unhook then just pull on the door handle as if to open it and it should slide right off other then that just making sure the button wiring harnesses don't get in the way. go to mustangworld.com i think they have a little video setion of taking the door panels off
Threads Similar to: Door Panel Removal
the door panel stinglikeastang V6 Mustangs 26 January 8th, 2009 12:23 PM
sail panel and a pillar removal? hellpppp energiesource 99-04 2 September 15th, 2007 02:55 AM
Removing 94 door panel Murderjetz V6 Mustangs 18 July 21st, 2007 12:08 PM
door panel cam08 99-04 5 June 23rd, 2007 01:32 AM
door panel removal? aj2002ga Audio/Video 1 April 14th, 2007 11:15 PM
